Shock Tube Problem
Old   July 17, 2012, 15:51
Default Shock Tube Problem
8jdm1 is on a distinguished road
Hello, I am trying to model 2D flow in a shock tube using fluent. I was able to initialize the flow by imposing initial conditions as such: at t=0, P driver= P4 (patching) with helium, Pdriven= P1 (default init) with Air, The problem is that the results of pressure and Mach number do not agree with the analytical inviscid solution. For some odd reason, I see a sustained high mach near the diaphragm throughout the entire simulation, as a result, there are two incident shocks generated. Any one had the same problem? What is the best way to initialize the problem.
Thanks
-JD
8jdm1 is offline   Reply With Quote
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
analytical solution of 1D shock tube problem ma Main CFD Forum 10 May 11, 2015 05:20
the shock tube problem and its artifacts with sonicFoam emjay OpenFOAM Running, Solving & CFD 0 December 16, 2011 07:58
Lax-wendroff scheme for Shock tube problem. manukamin Main CFD Forum 1 November 26, 2011 14:10
using ghost fluid method in shock tube problem Amir Main CFD Forum 4 February 24, 2011 10:09
