Contours are not displayed!!!!
Old   July 16, 2012, 15:21
Exclamation Contours are not displayed!!!!
jeddah boy
viky is on a distinguished road
hi,
i have made a geometry in GAMBIT and have imported it in Fluent. It gets itterated and solution converges, but the problem arrises when i WRITE the file as CASE & DATA to save it. As i re-open the saved CASE and DATA file the following ERROR massage is displayed
""Note: zone-surface: cannot create surface from sliding interface zone.
Creating empty surface"".
and in some other cases i get the message
Error: Not a pair
where i am doing wrong??
viky is offline   Reply With Quote
Old   July 17, 2012, 02:18
lxlylzl is on a distinguished road
I think you might have come across the same problem (i mean same error message displayed) when importing mesh file to FLUENT. If it is so, go back to GAMBIT and create the mesh properly with well defined zones. Hope this will help you. By the way in which format are you importing your model in GAMBIT. Try ACIS.
lxlylzl is offline   Reply With Quote
Old   July 18, 2012, 05:19
raymond
wlt_1985 is on a distinguished road
Originally Posted by viky View Post
hi,
Error: Not a pair
Something wrong to your setting. Check your boundary conditions.
wlt_1985 is offline   Reply With Quote
aqstax, federvo.mala
[Fluent] Problem in Mach Contours Hybrid FLUENT 4 February 13, 2012 02:21
About velocity angle when plotting a contours wateraction FLUENT 0 July 24, 2010 23:24
Preconditioning and pressure contours ganesh Main CFD Forum 2 February 18, 2006 00:02
extension for liquid fraction contours venugopal FLUENT 0 June 11, 2004 01:27
contours of F_UDMI Nici FLUENT 8 September 3, 2003 03:41
