source term contours?
Like Tree1Likes
  • 1 Post By coglione
Old   July 18, 2012, 16:53
Default source term contours?
Erica
Magneto is on a distinguished road
Hi Everyone,
I am using UDFs to add source terms to my domain. I would like to view contours of the source terms, which vary over the volume, in the same way Fluent lets you view velocity or pressure contours. Does anyone know how to do this?
Thanks a lot!
Magneto is offline   Reply With Quote
Old   July 19, 2012, 04:50
Max
coglione is on a distinguished road
Activate a User-Defined_Memory Define/User Defined/Memory and fill it within your Define_Source-Macro using something like
C_UDMI(c,t,0) = source;
Contours of UDM can be post processed like any other variable.
cheers
czhao86 likes this.
coglione is offline   Reply With Quote
Old   July 19, 2012, 13:10
Default Thank you!
Erica
Thanks! This is very helpful!
Old   July 20, 2012, 09:08
Default Define macros
mila_oliv is on a distinguished road
To do so do I have to use any specific define macro?
And what about compiling and hooking, just like tutorial shows?
mila_oliv is offline   Reply With Quote
Old   July 20, 2012, 11:27
Erica
I just stuck the command
into my DEFINE_SOURCE macro where I calculate the source. This stores the source in user-defined memory location 0. Note that you have to allocate this memory before running the simulation (in the user-defined memory menu) or you will get an error.
Old   July 20, 2012, 12:16
Thanks, Magneto!!
contours, source
Problem of SOURCE term gradient in UDS wind Fluent UDF and Scheme Programming 6 December 1, 2022 14:21
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
UDF source term jerome_ FLUENT 2 July 11, 2011 11:55
How to write source term into scalar Fiel JimKnopf OpenFOAM Programming & Development 0 March 23, 2011 05:59
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
