Rotating domain for VAWT 3d simulation
Old   July 23, 2012, 14:51
Default Rotating domain for VAWT 3d simulation
Jorge Tamayo
Jorg is on a distinguished road
Hi everyone, im currently trying to simulate the flow around a VAWT with helical blades. I´ve used both sliding mesh and Multiple reference frame models but in both cases, everytime i plot any contour for pressure or velocity the solution for the rotating domain seems to be independent from the main stationary flow field; i.e. the values of the flow variables change abruptly at the mesh interface between the stationary and rotating domain.
I wonder if anyone can give me some guideline or advice about this situation.
Thanks!
Jorg is offline   Reply With Quote
Old   July 24, 2012, 11:17
jpcfd is on a distinguished road
Are you sure you are plotting the velocity in the global reference frame.. check the variable you are choosing in the drop list.
jpcfd is offline   Reply With Quote
Old   July 24, 2012, 15:17
Default thanks!
Jorge Tamayo
I just did, jpcfd, it works! but the option i have available (and that worked for me) is 'velocity in stn frame' if i'm not wrong, once i select that option it doesn't seem to be a relevant difference between the global or local domain. Thanks a lot, that problem has been clarified.
Now i'm dealing with a negative moment coefficient, i hope to find out a solution wether it is from the simulation or from the turbine design.
Thanks again!
the rotating domain simulation lius Main CFD Forum 3 July 8, 2017 08:33
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Rotating domain motion in cfx post pankaj CFX 6 September 5, 2007 14:28
Difference b/t rotating wall and rotating domain? Juno Kim CFX 2 February 20, 2007 20:08
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
