December 14, 2016, 13:47 |
Air that is not flowing in a closed system
Onur Özcan
Rep Power: 12 |
Hi all,
I am working on 3d temperature distribution of some moulds. There is a closed system that has only air not flowing there in moulds. As the system is closed, density must be constant (mass and volume are constanst). Cp and thermal conductivity are defined as piece-polynomial. Thing I would like to ask is which state should be there? solid or fluid, as air is not flowing, I have defined it as ''SOLID'' . What should I do? Is there any thought? |
December 15, 2016, 01:51 |
Lucky
Rep Power: 66 |
If it's flowing it must be a fluid. Solids don't flow.
December 15, 2016, 02:05 |
Onur Özcan
Rep Power: 12 |
that is, I have done correct one ! Air should be defined as solid if it is in closed system, (1 wall, others are interface)
Air entrainment model setup for spillway | oajor | FLOW-3D | 4 | November 17, 2016 12:02 |
Steady state free surface flow in rotational closed system | hilde | CFX | 5 | January 21, 2015 16:47 |
Boundary conditions for water jet into air in a closed chamber | vishal_s | OpenFOAM Running, Solving & CFD | 0 | August 20, 2013 03:27 |
Geometry BC's for coupled DPM water spray in closed container of air | dan86 | FLUENT | 0 | July 24, 2013 05:10 |
Charge air system modeling | Lars Ola Liavċg | Siemens | 0 | September 10, 2001 08:23 |
