August 2, 2012, 04:31 |
low Reynolds number problem
john
pls anybody could tell me how can i define Reynolds number in a forced convection over 4 planar heat sources placed in line inside a test section of a wind tunnel?
the Re curresponds to flow over a flat plate is very low. but its not getting converged in laminar model of FLUENT. |
August 2, 2012, 05:21 |
Alex
Rep Power: 47 |
The characteristic length for the flow over blunt bodies is usually the width of the body.
August 7, 2012, 12:55 |
john
the heat source is similar to flat plate. but 4 such heat sources are arranged in tandem with a gap of 10 mm between them. so can i consider its total length or length of single heat source for defining the Reynolds number?
August 8, 2012, 03:01 |
Alex
Rep Power: 47 |
Why is it so important to define a Reynolds number for this case?
For complex flows, the choice of a characteristic length is quite arbitrary. |
Low Reynolds Number SST Model | Josh | CFX | 41 | June 4, 2023 19:00 |
plotting drag coefficient in low reynolds number flow past cylinder | atmcfd | FLUENT | 0 | January 2, 2010 08:34 |
Low Reynolds number airfoil. | Pablo Cornejo | FLUENT | 14 | October 19, 2005 09:41 |
About low Reynolds number airfoil experiment data. | zqnwpu | Main CFD Forum | 5 | December 25, 2004 03:52 |
