Do I need PRESTO!?, Body force weighted or ??
Old   September 29, 2007, 23:38
Default Do I need PRESTO!?, Body force weighted or ??
jrg
Hi. I have a jet hitting a wall before leaving the outlet located at one end of the wall. Between the impingement point and the outlet, there are some swirls. Flow is incompressible and laminar.
In this case, should one apply a more elaborate pressure discretization scheme? I used the standard scheme and the outlet pressure is off by 20% compared to expt data. When I tried PRESTO!, solution diverges.
Old   September 30, 2007, 18:38
Default Re: Do I need PRESTO!?, Body force weighted or ??
jrg
To elaborate further, I also use the SIMPLEC. When in combination with PRESTO and with skewness correction of 1 or more, solution diverges. Without skewness correction, convergence can be achieved.
The question now is if skewness correction is necessary? Does it change the solution or does it affects only convergence speed?. The mesh is an unstructured hex.
If I use body force weighted, I can get a stable solution even with some skewness correction.
Can someone make sense out of these observations?
Old   August 31, 2012, 10:33
Default PRESTO! or BFW ??
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi everybody,
I'm modeling a heat source in a closed room. My mesh is quite dense: 4M tetra (around the source) and 4k Hexa (far from the source).
Can anybody tell me which discretization method for pressure is better? PRESTO! o BODY FORCE WEIGHTED? What are the differences between them?
Thanks in advance
Bionico
Bionico is offline   Reply With Quote
Old   September 3, 2012, 07:38
Bionico's Avatar
Flavio
I read something about the presence of corners: for this reason PRESTO! should be better. Can anyone confirm it?
Bionico
Old   January 22, 2018, 07:32
Yuehan
wc34071209 is on a distinguished road
Have you found the answers? I asked a similar question but have not received help yet.
wc34071209 is offline   Reply With Quote
Force can not converge colopolo CFX 13 October 4, 2011 22:03
gravity terms & Body Force Weighted meshkati Main CFD Forum 0 January 4, 2010 04:06
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 08:54
Body Force weighted Sanxian Main CFD Forum 0 June 15, 2007 08:21
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 03:06
