Inappropriate zone type, inability to change to interior & skipping of zones |
August 22, 2012, 14:50 |
Taiwo
Rep Power: 14 |
Hi all,
Please, assist me to fix these probems: Problem 1 I imported a mesh from Gambit into Fluent. The pictorial representation of the grid is attached. The cut1 & cut2 are the two holes that pass through the thickness of the strip. The strip is then inserted into the tube. The following message appeared on the console: Warning: Inappropriate zone type (interior) for one-sided face zone 5. Changing to wall. Error: Cannot change cutflow1 to interior because there is only one adjacent cell thread. Error Object: #f cutflow1 Error: Cannot change cutflow2 to interior because there is only one adjacent cell thread. Error Object: #f cutflow2 Problem 2 I imported a mesh from Gambit into Fluent. The pictorial representation of the grid is attached. (the same grid as in Problem 1). The cut1 & cut2 are the two holes that pass through the thickness of the strip. The strip is then inserted into the tube. The following message appeared on the console: Removing 1157 unreferenced faces, zone 5. Removing 1143 unreferenced faces, zone 6. Warning: Number of nodes read (349210) does not match number referenced (346734). Resetting counter to match the number referenced. Skipping zone cut1 (not referenced by grid). Skipping zone cut2 (not referenced by grid). |
cell, interior, node, thread, zone |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
boundary conditions for simpleFoam calculation | foam_noob | OpenFOAM Running, Solving & CFD | 8 | July 1, 2015 08:07 |
[blockMesh] StitchMesh on two patches | anita | OpenFOAM Meshing & Mesh Conversion | 31 | April 4, 2013 11:51 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
