Time step size, number of time steps and max iterations per time step
Like Tree1Likes
  • 1 Post By thecfduser
Old   December 4, 2009, 05:07
Default Time step size, number of time steps and max iterations per time step
Guido
guido_88 is an unknown quantity at this point
I'm modeling a flow in an open-open pipe with a sinusoidal UDF. My frequency is 2000 Hz. How I can set time step size, number of time steps and max iterations per time step ? I want that it resonate so i find that it has to be 8.43cm long and 1cm of diameter
guido_88 is offline   Reply With Quote
Old   December 4, 2009, 12:34
karine
thecfduser is on a distinguished road
Hi
Time step = 1/2*2000.
Number of time steps: u must continue ure simulation untill u obtain a steady (oscillatory of course) solution. U will need at least that ure fluid traverse the pipe for 2 times , i mean 2*V/L
Max iteration by time step: try to monitor variables...choose the max iter. as the number of iterations after what ure solution does not change anymore within a time step....(u can also add 1 iteration for security, this ure unsteadiness is not uniform)
If those condirtions are so strict (take a lot of time to finish ure simulation), use NITA solver: it will give u fairly accurate solution within 1 iter by time step
P.S be4 asking a question, u can say hello and at the end, u can say thanks no?
thecfduser is offline   Reply With Quote
Old   December 4, 2009, 12:40
Guido
Thanks a lot,you're absolutely right !
I'll try to follow your suggestions, thanks again !
Old   December 4, 2009, 13:11
karine
No problem comrade
Anyway i forgot to tell u, for the time step i told u 1/4000 to stay conform to shannon theorem...but if u have more unsteadiness, u must use a smaller time step.
URANS models are not sensible to high frequencies, so this will not be a big problem but if u are performing DNS or LES, u will need maybe to refine ure time step...
There is no universal formula: the best way is to perform ure simulations with 2 different time steps and compare so u can be sure.
With smaller time step, u will need less ietrations by time step. Sometimes using a smaller time step only influences rms values without influencing the mean field...
Good Luck
chek321 likes this.
Old   August 30, 2012, 14:49
Default how to calculate time steps required in a transient analysis
abdul khader
smak.quadri is on a distinguished road
I am performing FSI analysis on a elastic tube.
Total time is 0.8sec and I am using timestep of 0.005sec.
How can we calculate the required no. of time steps for a total time. is there any thumb rule for this ..? or its always a guess..?
kindly reply
smak.quadri is offline   Reply With Quote
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
TurbFoam problemlarge Co number sunnysun OpenFOAM Running, Solving & CFD 6 March 10, 2009 08:05
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 15:15
