AMG solver
Old   January 10, 2007, 11:21
Default AMG solver
Wang
When I run a case, an error occurred. The error information is as follows:
Error: divergence detected in AMG solver:x-momentum Error Object:#f
It is appreciated to share similar experience.
Thanks,
Old   January 10, 2007, 12:01
Default Re: AMG solver
KP
Tighten your under relaxation factors and then run. For instnace check on momemtum under relaxation factors now say its 0.5 tighten it to 0.1. Then this error should go away. However doing this increase your tun time. KP
Old   January 10, 2007, 15:56
Meng
For my case, it also happens when I changed to a parallel solver with auto partition. After I used Metis partition, it disappeared.
Meng
Old   January 12, 2007, 06:58
Wang
Thanks! using coupled solver and a smaller urf, the case is working.
Old   March 13, 2012, 12:48
Default divergence detected in AMG solver: x-momentum
zainab p
zeybi1604 is on a distinguished road
Hello. i am doing a multiphase simulation in a packed bed using the mixture model. the volume fraction used was 0.5316.i keep getting the error message "divergence detected in AMG solver: x-momentum" for all the different solvers used and i even changed the under relaxation factors. i really have no idea how to proceed with this simulation!plzz help!thank u.
zeybi1604 is offline   Reply With Quote
Old   September 21, 2012, 03:40
bahare
bahare is on a distinguished road
http://cape-forum.com/index.php/topic,446.0.html
bahare is offline   Reply With Quote
Fluent IcePak - AMG Solver Russ FLUENT 2 December 31, 2018 09:57
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Divergence detected in AMG solver: pressure correction jimmer FLUENT 2 August 7, 2010 06:47
reverse flow and divergence in AMG solver MASOUD FLUENT 2 April 2, 2010 08:48
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 15:15
