Laminar air flow in a 2D channel
Old   November 5, 2012, 01:03
Default Laminar air flow in a 2D channel
Adel
Addeeellll is on a distinguished road
Hello dears,
I have a problem, I am doing simulation of a laminar airflow in a 2D channel which is from an article but I cannot reach the desired results. I don't know where the problem exists. could anybody help me as it's urgent.
Thank you
channel: 20mm (H) x 40mm (L)
100<Re<600
Dh (hydraulic diameter)= 40mm
T inlet=300K
T wall=330K (const.)
the Nu number obtained in the article is around 7.54 from Re=100 to Re=600
the friction factor in the article would decrease with the increase in Re number
it is written in the article that the flow is a constant mass flow rate but it has not talked about the 3rd dimension of the channel in order to obtain mass flow rate. also it has not talked about the entrance length which causes the flow to be fully developed.
Addeeellll is offline   Reply With Quote
Old   November 5, 2012, 02:46
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
Hi Adel,
Be more specific, What is the problem exactly? What boundary conditions do you use?
About the mass flow rates; You can calculate the velocity entering channel by the values of the total pressure and mass flow rates. Then setup your boundary conditions as pressure inlet and outlet ( regarding to have a friction loss in your case, you will be able to calculate the pressure drop). By initializing the solution, the solver will calculate the inlet and outlet velocity as desired.
Regards.
vicarious is offline   Reply With Quote
Old   November 5, 2012, 03:05
Adel
Hi vicarious,
Thank you for your concern
my case consists of 2 parts:
1st: laminar 2D airflow in a smooth channel in which the upper and lower walls are at constant temperatures (330 K) and the inlet temperature is 300 K.
I can use Re= (ρuD_h)/μ to find the inlet velocity or use mdot=ρuA_c to obtain mass flow rate. but to obtain the mass flow rate with this formula, the cross-section area should be known which is the area normal to the flow direction but it is not mentioned in the article.
I decided to use velocity inlet. but the entrance length should be known for a flow to be fully developed. with the formula, l=0.05*Re*D_h=1200mm but the results of the FLUENT software is totally different with the ones from the article.
(in the article for smooth channel: Nu≈7.54 for Re=100 to 600 and f decreases from around 0.1 at Re=100 to around 0.14 at Re=600
Old   November 5, 2012, 04:09
vicarious's Avatar
Pedram Mojtabavi
None of your dimensions are determined in your article? height and depth? In that case mass flow or velocity do not help. You have to have at least one of the dimensions, otherwise you need to have the inlet total and static pressure and outlet static pressure so you do not need velocity in this case. Maybe somewhere in the article, the operating pressure and pressure drop are mentioned. I also suppose the entrance correlation is proximate formula for calculating the hydraulic diameter, that's why it does not give the correct answer.
Old   November 5, 2012, 04:45
Adel
it has given the dimensions as I wrote above: 20mm (H) x 40mm (L)
The operating pressure is atmospheric pressure(101Kpa)
the gauge pressure at the outlet is 0
Old   November 5, 2012, 05:16
vicarious's Avatar
Pedram Mojtabavi
Since you have airflow through the channel and D_h is determined, so you can calculate the velocity by the same Re formula, then calculate the dynamic pressure (P_v=0.5*ρ*u*u). then you will have the static pressure (P_s=P_total - P_v). Enter these parameters as pressure inlet and outlet and you do not need the velocity and mass flow anymore, the solver will calculate it itself.
Old   November 5, 2012, 05:33
Adel
Thank you very much
but I can use VELOCITY INLET for the inlet boundary condition, can't I?
another problem is the ENTRANCE LENGTH. it is not mentioned in the article and using the formula 0.05*Re*D will not give a good result in fluent.
May I have your Email?
Thank You
Old   November 5, 2012, 06:06
vicarious's Avatar
Pedram Mojtabavi
You are quite welcome.
Velocity boundary is also accessible but the inlet pressure will be unknown, therefore the outlet pressure would be a problem and may cause in reversed flow. You need to put constraints as pressure so the solver will handle it.
Regarding to the entrance length, If the article uses the theoretical correlations for boundary layer approach, then all of them are weak solutions. Since the correlation you mentioned is not exact, you can determine it numerically. The boundary layer thickness is where the u(y)=0.99u_freestream. So you can extract the values of your u(y) from simulation and look up for the location where y reaches to the h/2 (h:height).
Here is my email : pedram.mojtabavi@gmail.com
Best Regards.
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
mulltiple channel flow I.Dotsikas Main CFD Forum 2 September 23, 2010 20:49
open channel flow with a layer of air Naomi CFX 1 November 15, 2008 06:34
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 02:52
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
