2D LES in FLUENT for a turbulent jet
Old   February 20, 2012, 21:33
Default 2D LES in FLUENT for a turbulent jet
CFD User
aditipatel7 is on a distinguished road
Can someone please help with the Fluent setting required to perform 2D LES of a turbulent jet at a velocity of 10m/s.
1) My domain size is 1.4 x 2.5 m and size of the inlet is 0.1m built in GAMBIT
2) Boundary conditions are
inlet as velocity inlet
Side walls as pressure outlets
Bottom walls as wall
Top wall (Outlet) as pressure Outlet
3) I am using a pressure based, transient, planar solver
4) Smogrinsky-Lilly Model with default settings.
5) Material is air
6) Under boundary conditions of the velocity inlet a setting of spectral synthesizer is used with turbulent intensity of 5 and hydraulic diameter as 0.1
7) Soultion Methods:
Least Square Cell Based, Standard Pressure, Bounded Central Differencing Momentum and Second Order Implicit for transient formulation
8) Solution Initialized from the Inlet.
9) Time step settings:
Size 0.001
No. of time steps: 1000
No. of iteration/time step: 1000
Can someone please point out to me where I am going wrong or what could be suggested for getting the correct flow..
Thanks
aditipatel7 is offline   Reply With Quote
Old   November 14, 2012, 02:33
Emil Baric
emil is on a distinguished road
Are you sure you want to do 2D LES? Because you are surely killing a part of physics by doing that. I know it is not much help but just re-consider
emil is offline   Reply With Quote
Old   November 14, 2012, 02:44
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
This is true. You can not do LES in 2d. But emil, why do you reply such an old thread?
RodriguezFatz is offline   Reply With Quote
Old   November 14, 2012, 03:34
Emil Baric
Sorry did not look at the date. my mistake
2d les of turbulent jet, need desperate help!
LES of a confined impinging jet reactor.. vishwa OpenFOAM Running, Solving & CFD 8 December 7, 2010 18:11
What is "Resolved Reynolds Stress" for LES model in Fluent? ivanbuz FLUENT 0 November 1, 2009 16:36
LES in Fluent and CFX taedeneo Main CFD Forum 2 May 6, 2008 13:53
turbulent jet ramo Main CFD Forum 1 September 4, 2005 07:43
Turbulent Intensity good or bad for a jet Christian Main CFD Forum 0 November 19, 2003 05:47
