Simulation flow loop of Heat exchanger
Old   November 21, 2012, 23:27
Default Simulation flow loop of Heat exchanger
benny95
lalolala is on a distinguished road
Dear all,
Anyone has ever done heat exchanger simulation? mind if share info with me?
im doing simple flow loop heat exchanger. But im having trouble in set up the model in FLUENT. the result was not what it suppose to look like. there is no flowing detected, no heat transfer, just a model with different color.
So if anyone have the step by step how to set up heat exchanger in FLUENT, appreciate if you can share with me pls.
i need to know the BC, temperature range, pressure, velocity, material properties and etc..
thanks
lalolala is offline   Reply With Quote
Old   November 21, 2012, 23:53
benny95
this is what my result look like..pic 2 show the water inlet and outlet...no flow going on...whats wrong with this??:con fused:
pls anyone help...urgent.!
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 06:33
Continuity convergence issue for a multiphase flow in a counterflow heat exchanger Andrea1984 Fluent Multiphase 2 July 24, 2013 04:55
two-pipe heat exchanger simulation lalehsh CFX 1 May 22, 2012 19:25
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 03:13
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
