moving wall at variable speed in Fluent
Old   July 31, 2000, 11:30
Default moving wall at variable speed in Fluent
Kai Kang
Hi all, I am working on a mixing study with a complicated mixing protocol requires the impeller to vary the rotating speed during the mixing cycle (about 250 cycles). However, it seems the moving wall in Fluent does not accept UDF, is there any way to modeling this (ie, slip velocity?) without the need to modify the case file for each cycle?
Old   November 26, 2012, 03:43
muthuraj
muthurajct@gmail.com is on a distinguished road
Use moving reference frame method
muthurajct@gmail.com is offline   Reply With Quote
Two-Sided Wall in FLUENT mlippy38 FLUENT 18 March 20, 2024 06:39
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
UDF for slip and moving wall lichun Dong FLUENT 3 March 26, 2014 04:37
moving wall omid hosseini FLUENT 0 August 7, 2006 09:47
Flux depending on wall shear stress in Fluent 5.2 Andreas Borg FLUENT 0 June 7, 2000 06:27
