fluent
Old   June 21, 2011, 00:47
Default fluent
leila
leila.a is on a distinguished road
hi....
my project is about modeling in thermosyphon with nano fluid.
how can I define udf for nano fluid?
leila.a is offline   Reply With Quote
Old   June 21, 2011, 00:57
alighaffari
alighaffari is on a distinguished road
I think it won't be necessary to use UDF. You can directly define nanoparticles diameter in DPM model or other multiphase models.
alighaffari is offline   Reply With Quote
Old   June 21, 2011, 10:29
Amir's Avatar
Amir
Amir is on a distinguished road
Originally Posted by leila.a View Post
hi....
You have to use UDS instead. obviously, you may need writing UDF in order of including special terms in UDS equation such as source terms.
DPM is not a good suggestion for nano-fluid modelling because of its restrictions and bugs in small particles.
Amir is offline   Reply With Quote
Old   December 29, 2012, 19:03
fshak92 is on a distinguished road
Originally Posted by Amir View Post
Dear Amir,
I'd like to model a combination of ethylen glycol and silver nanoparticles .(the combination lies on a solid plate and then heats)
The viscosity of ethylen is in order of 1 cP but the combination of that should become about 70 cP.
Would you please give me a little explanation about using UDS regarding my problem?
thank you in advance.
fshak92 is offline   Reply With Quote
Old   December 30, 2012, 08:32
Amir's Avatar
Amir
Originally Posted by omid88 View Post
Dear Amir,
Hi Omid,
Sure; UDS is an additional scalar transport equation, you can use this capability of FLUENT to model the concentration of nano particles. In your case, the main media would be ethylen glycol and the UDS can be performed in order to model the concentration of silver particles. You have to bear in mind that in this procedure, you'll need extra UDFs defining the physical properties; e.g., viscosity, density, thermal conductivity and so on; obviously, these properties are functions of silver concentration. Hope that'd help.
Do not hesitate to ask if it's not clear or more elaborations are required.
Bests,
Amir
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
