December 18, 2012, 04:02 |
Non-reflective Boundary Condition divergence
Rep Power: 16 |
Hi all,
I'm currently trying to run a 2D axisymmetric calculation of a simplified engine exhaust on Fluent 14.5. I have thus one velocity inlet at 200m/s, one pressure outlet (gauge pressure = 0 Pa), and one pressure inlet (also 0 Pa). I ran it steady kwsst ==> ok Then unsteady kwsst ==> ok Then SAS ==> OK Then I'm trying to switch to 2d LES with the TUI command, which works fine, and doesn't diverge (but shows a very more chaotic comportment compared to SAS). Now, all of these runs were done with classic pressure BC. I now want to switch ON the non-reflective BC on the pressure outlet, still with the 2d LES. It diverges each time I try. My solver settings are the default ones when switching to that 2d LES. I tried dividing the time step by 5 (going to 1e-04s), reducing the courant number, going into more complex discretization schemes : it diverges always, and from what I see on the contour plots : it comes from the outlet. the mesh is like I said 2D, perfectly squared cells (10cm) everywhere, overall length of the model is about 40m and "radius" of the engine is about 2m. The starting point of the LES calculation is the SAS calculation, which seems stable and nice. I now switched the inlet BC to a "mass-flow" BC instead of velocity, but it doesn't look promising... I don't have any more ideas to try make it work, so can someone help ? thank you, Arnaud. PS : It is the pressure based solver, coupled. |
December 18, 2012, 04:50 |
Alex
Rep Power: 47 |
I hardly think that running an axisymmetric case with LES is physically valid.
So dont bother if it doesnt run. Switch to a 3D geometry if you want to run a LES. |
December 18, 2012, 04:57 |
Rep Power: 16 |
Yeah, you're right, but I'm not trying to get information really from this calculation, just trying to understand a little bit more the different models, so I'd like to run it 2d for starter. But of course I plan on going 3D after that.
December 18, 2012, 11:45 |
Alex
Rep Power: 47 |
In that case, a planar 2d simulation instead of an axisymmetric one might work better. I am not sure if the non-reflecting boundaries are suitable for axisymmetric cases.
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Boundary Condition for granular temperature Theta | cheng1988sjtu | OpenFOAM Programming & Development | 4 | July 4, 2016 16:08 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
