May 21, 2020, 09:44 |
one flowrate for two inlets
Rep Power: 6 |
Hi everyone,
I am trying to simulate the attached geometry. As it can be seen, there are 2 inlets. My goal is to supply 10LPM fluid into the system however I don't want to specify the flowrates for inlet1 and inlet 2. Is there a way to define 10LPM for inlet1+inlet2 and have fluent calculate how much fluid would flow through each inlets? |
May 21, 2020, 09:58 |
Merge
Just merge the boundaries into one and apply mass flow rate. Merge is available under Mesh in the top ribbon.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
August 2, 2020, 10:43 |
#3 | |
Rep Power: 6 |
I actually have tried your suggested approach few times. The problem is I get every time an equal distribution of flow rate. I have 2 fluid domains with different geometries an expect a variable distribution of flow rate. Do you have any ideas? |
Mixture of the same fluid from 2 inlets | godon | Fluent UDF and Scheme Programming | 0 | October 15, 2012 08:04 |
Two pressure inlets problem | Medison | CFX | 1 | August 22, 2012 06:50 |
increased flowrate decreased in heat rejection? | mactech001 | CFX | 24 | April 12, 2010 13:08 |
Multiple Inlets | Charlie V | FLUENT | 0 | May 28, 2001 02:29 |
create Volume with inlets | Roman Bohnes | FLUENT | 10 | December 6, 1999 04:43 |
