December 30, 2012, 16:44 |
mixture
Nasser
Rep Power: 13 |
hi friends
I wanna model ferrofluid with mixture , I can't select solid for secondry phase , I need magnetic permeability for particle so I cant select a liquid and change its propertis because liquid has not magnetic permeability . tnx |
December 30, 2012, 23:39 |
SSL
Rep Power: 14 |
You can use porous media for solid media.
Also you can use eurlerian multiphase flow to implement solid in the second phase. |
December 31, 2012, 03:14 |
Nasser
Rep Power: 13 |
hi
tnx but in Description of eulerian model said that :If your model includes a particulate (granular) phase, you will need to create a new material for it in the fluid materials category ( not the solid materials category) I have to change properties of fluid to solid property but in fluid we havent magnetic permeability to change it and I have magnetic field AND it have to influence into particle in my model . |
January 2, 2013, 05:45 |
#4 | |
Yanlong Li
Rep Power: 13 |
January 2, 2013, 12:49 |
Nasser
Rep Power: 13 |
tanx again
I change database of materials and my problem was solved |
Mixture and Decay of a tracer in a Water Tank | Jeffrey1992 | CFX | 2 | July 27, 2012 13:31 |
mixture mass continuity eqn v.s. volumetric mixture continuity eqn | kaifu | ANSYS | 0 | June 9, 2011 08:42 |
mixture mass continuity v.s. volumetric mixture continuity in pressure equation | kaifu | OpenFOAM | 0 | June 9, 2011 08:14 |
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC | richpaj | OpenFOAM Bugs | 2 | October 9, 2008 22:14 |
Burning a CH4-H2 Mixture | Jonathan Lemay | CFX | 2 | November 12, 2007 17:01 |
