Low Flow Convergence Help
Old   January 6, 2013, 14:10
Default Low Flow Convergence Help
Ryan Persaud
rypersaud is on a distinguished road
Hey guys, need some help with convergence. The application involves a 3" inlet pipe with 52 m/s velocity discharged into a 26"X50" duct. The duct has a U-bend with a 20" outlet.
This is a very slow flow problem due to the large size of the duct. We are expecting the velocity at the outlet to be approximately 1 m/s.
Used a surface monitor plot at the outlet to look at the velocity, and scaled residuals criteria of 1e-5. The velocity of the outlet appears to have approached a value, however the residuals are quite high. I ran 5000 iterations to exclude the effect of under relaxation factors. I have posted the plots below.
Any suggestions, or direction on how to improve the model will be great. Thanks!
rypersaud is offline   Reply With Quote
Old   January 7, 2013, 00:13
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Seems like everything is okay except for residuals.
Have you tried a finer grid? What about discretization schemes, 2nd order upwind on all?
LuckyTran is offline   Reply With Quote
Old   January 7, 2013, 11:23
Ryan Persaud
I am using a student version of Fluent so I'm limited to 500000 cells and I'm using 2nd order for everything. I'm also using the Simple solver....would using another one help? any other ideas?
Old   January 7, 2013, 23:59
SSL
msaeedsadeghi is on a distinguished road
It is better to use the simplest form (First Order).
It is obvious that the problem is with your mesh. Refine it and try to make a structured mesh.
msaeedsadeghi is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 06:32
Convergence for axisymmetric flow bl201 Main CFD Forum 5 August 16, 2005 17:01
CFD code for very low Re Flow Raj Main CFD Forum 2 May 31, 1999 22:06
