Meshing in CHT Problem
Old   January 8, 2013, 15:24
Default Meshing in CHT Problem
Markat is on a distinguished road
I try to mesh my geometry (thin plate). The minimum orthogonal quality is about 0.1 and the average about 0.9. The residuals are about 1e-05 after 1000 iterations and can not be further reduced.
Some elements have negative value of wall heat transfer, which I cannot physically explain.
1. Is it important to use inflation or should I ignore inflation to achieve a better minum orthogonal quality?
2.Should I try to use Polyherdal meshing to improve minimum orthogonal quality? Can Polyherdal meshing be used for CHT problems? When I used Polyhedral meshing the maximum value of wall heat transfer was being almost doubled in comparison with Tetrameshing. How could you explain this?
Thank you in advance
Markat is offline   Reply With Quote
Old   January 10, 2013, 15:56
Could anybody please help me?
Old   January 13, 2013, 12:36
Does anybody have any idea?
Old   January 13, 2013, 12:59
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
post screenshot of you mesh !! and your geometry !! is it 2d or 3d ?? what software did you use to mesh ??
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 13, 2013, 13:45
Thnak you for yyour reply! My mesh is 3d and was made in Ansys Mesher (Workbench)
Old   January 13, 2013, 13:57
diamondx's Avatar
Ghazlani M. Ali
can i see how it looks like
Regards,
Ali
Old   January 13, 2013, 15:14
I unfortunately don't have an availiable picture of my meshing right now, but I will post one as soon as possible! Thank you in advance for your help
Old   January 13, 2013, 15:16
Just to imagine it looks like an thin airfoil in a wind tunnel. Only a the fluid was being meshed (I used boolean subtraction to create the appropriate geometry).
Old   January 13, 2013, 15:38
diamondx's Avatar
Ghazlani M. Ali
it should be easy to mesh with a structured mesh under ICEM are you familiar with icem. when the geometry is easy; always go for a structured mesh if you can.
Regards,
Ali
Old   January 13, 2013, 15:45
Thank you for your advice! I tried to do a structured mesh! Unfotunately the mesh in the area near the airfoil (cambered) can not be structured.
When I try smoothing the meshing in Fluent I got a better minimum orthogonal quality (~0.4). The simulation result remained unchanged (energy residuals do not ger below 10^-5 so I thought I should try to solve my problem transient)!
[ICEM] Meshing problem in Formula one Far ANSYS Meshing & Geometry 113 April 23, 2013 12:36
CHT Problem with moving solid part MaxHeat FLUENT 1 November 28, 2012 03:06
[GAMBIT] fac meshing problem, not skewness bugra ANSYS Meshing & Geometry 0 September 3, 2010 07:40
problem meshing with low y+ cesco FLUENT 8 February 23, 2009 05:12
problem with gambit unsymmetrical meshing meenakshi FLUENT 1 March 28, 2008 12:46
