January 20, 2013, 21:56 |
Body to rotate by action of the air flow - 6Dof Solver + Moving Object in fluent
Pouyan Jahangiri
Hi everybody. I need your help.
Here, I have a channel (2D) with a inclined rectangle in the middle and I'd like to simulate the rotation of this object by action of the fluid flow. I've been using a 6DOF udf together with dynamic mesh, but when I run the solver, the rectangular object wont rotate. I decreased the values of Moment of Inertia to even very low numbers, but it didn't rotate again. Would it be possible to help me what to do? I used the following UDF file (however I Changed the values of mass and moment of inertia): DEFINE_SDOF_PROPERTIES(body, prop, dt, time, dtime) { prop[SDOF_MASS] = 666.66; prop[SDOF_IXX] = 129.6296; prop[SDOF_IYY] = 111.1111; prop[SDOF_IZZ] = 129.6296; printf ("\n2d_test_box: Updated 6DOF properties"); } Last edited by PouyanJ; January 21, 2013 at 00:38. |
August 21, 2013, 05:43 |
Thành
Rep Power: 12 |
Hi PouyanJ
I think that you should be addition some water's property density of water, sound of water in your UDF. Can you read more detail in " Falling box in water " Tutorial ansys fluent Good Luck! |
September 25, 2013, 07:49 |
like.no.other
Rep Power: 14 |
Hi Pouyan
If you want to simulate only rotation of body, you must restrict the motion in other directions. you should use this macro for restriction of motion: prop[SDOF_ZERO_TRANS_X] = TRUE; prop[SDOF_ZERO_TRANS_Y] = TRUE; prop[SDOF_ZERO_ROT_X] = TRUE; prop[SDOF_ZERO_ROT_Y] = TRUE; |
August 1, 2014, 19:33 |
Mahdi Torabi Asr
Rep Power: 12 |
Dear Pouyan, may I know your dynamic mesh setup. Maybe this problem comes from ill dynamic mesh configuration.
August 7, 2014, 03:13 |
arash
Rep Power: 11 |
Hi everyone
I have been working on moving projectile i barrel. I need udf for dynamic mesh(Six degree of freedom solver). can anyone help me? |
August 18, 2014, 01:26 |
#7 | |
Rep Power: 13 |
if you want to just simulate "moving" use this and replace your weight: #include "udf.h" DEFINE_SDOF_PROPERTIES(proj, prop, dt, time, dtime) { prop[SDOF_MASS] = 1; } the other progress of solve is in "projectile moving inside a barrel"pdf that you want it i can send it for you |
August 18, 2014, 02:49 |
arash
Rep Power: 11 |
Thank you for the reply
I just have pdf file of this tutorial, could u please send me the case and data files of tutorial? Thanks a lot amin.ntea@yahoo.com |
October 15, 2014, 21:18 |
#9 |
Hi, all
Could you please also send me the following falling box files: 6dof-mesh.msh.gz 6dof_2d.c at sxh@dlut.edu.cn thanks! Best Regards sxh |
November 18, 2014, 07:54 |
#10 |
Rep Power: 11 |
Thanks for the help.
November 18, 2014, 08:05 |
#11 |
Rep Power: 26 |
These files can be downloaded from the ansys customer portal.
Log in, go to "Tutorials & Training Materials", and search for "falling box". |
February 23, 2015, 07:48 |
#12 | |
Amin
Rep Power: 14 |
I'm also looking for these files ( case, data & UDF of moving projectile inside barrel) could you please send these files to me if you find them? CFDSimulation@yahoo.com Last edited by amin.z; February 23, 2015 at 09:19. |
February 23, 2015, 08:57 |
#13 |
Rep Power: 26 |
February 24, 2015, 08:57 |
#14 |
Amin
Rep Power: 14 |
guys! I can't find the tutorial file in ansys customer portal!
I need your help! anyone could help me to find these files? a direct link to ansys customer portal or a keyword to find these or something like this! The files are: Tutorial: Projectile Moving Inside a Barrel projectile.msh.gz aneos.c six_dof_property.c |
September 30, 2015, 14:40 |
#15 |
tuananh
Rep Power: 10 |
Hi dear pakk!
I'm also looking for mesh and udf file for this tutorial: the box falling the water. could you please send these files to me if you have? Thansk a lot. My email: tuananhtran.kthk56@gmail.com |
October 6, 2015, 15:27 |
#16 |
Anonymous
Hi, all
Could you please also send me the following falling box files: 6dof-mesh.msh.gz 6dof_2d.c at rqb7231@yahoo.com thanks! Best Regards |
October 6, 2015, 19:55 |
#17 |
Jesse
Rep Power: 10 |
Hi, I'm just using the free student version of Fluent and so don't have a login to the customer portal. If someone could please email the files for the box falling in water and/or the bullet in the gun barrel I would really really appreciate it! Email: jesse.anderson303@gmail.com
Best regards Jesse |
October 29, 2015, 17:52 |
Looking for the tutorial files of box falling in water
#18 |
Edgar
I am trying to do a simulation to observe the behavior of a macroscopic particle in a stream flow. I think that this tutorial will be very helpful, but I do not have the UDF file. Could someone share with me these files (6dof-mesh.msh.gz and 6dof 2d.c), please? My email is: eem370@mail.usask.ca Thanks |
February 28, 2016, 09:10 |
Hi guys
#19 |
Rep Power: 10 |
March 17, 2016, 05:33 |
Body to move by action of the fluid flow - 6Dof Solver + Moving Object in fluent
#20 |
harshit dariya
Rep Power: 10 |
i have a problem in move body by the action of fluid flow. for that i want udf. so that i can move body in particular direction with the help of action of fluid flow. in my problem i want to move piston under cylinder. |
Prescribed object motion and 6DOF | vinz | OpenFOAM Running, Solving & CFD | 1 | September 23, 2013 07:37 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Changing from STAR to FLUENT - Solver Troubles | BastiL | FLUENT | 0 | February 15, 2008 16:41 |
2D flapping foil- moving ref frame model in Fluent | VJ | FLUENT | 0 | October 20, 2007 01:15 |
Moving Dynamic Mesh in Fluent 6.2 | R.M.Bharath Somayaji | FLUENT | 0 | January 9, 2006 20:36 |
