Need help with simulation of Chemical Mechanical Planarization in Fluent
Old   January 23, 2013, 00:29
Post Need help with simulation of Chemical Mechanical Planarization in Fluent
Navin Raj Natarajan
nnavinraj is on a distinguished road
For my dissertation I'm trying to simulate Chemical Mechanical Planarization process in Ansys Fluent to study the flow of slurry through the grinding setup and its pressure distribution and other parameters. What is the best way to go about this?
I have the following info:
  1. The slurry is composed of water and colloidal silica.
  2. I have made the model of the setup through which the slurry flows and attached it to this post.
  3. The gap through which the slurry flows is about 40 microns.
  4. From my searches I have determined that the Eulerian Model must be used for multiphase slurry flow.
  5. I need help/info on how the remaining options/parameters are to be chosen!!
Any help is appreciated.
nnavinraj is offline   Reply With Quote
cmp, euler, fluent, multiphase, slurry
IC engine simulation tutorial by FLUENT yash FLUENT 4 April 6, 2015 19:44
Combustion SImulation in Fluent santhosh1987 FLUENT 0 May 14, 2010 10:32
Why is my fluent simulation giving Cp values above 1??? wils Main CFD Forum 3 March 26, 2010 09:12
IC engine simulation tutorial by FLUENT yash Main CFD Forum 1 April 21, 2009 05:05
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 05:38
