January 23, 2013, 05:28 |
Adaptive Timestep in Eulerian Multiphase?
Bayard Morales
Hi there.
I am running a gas-solid euler-euler transient simulation in Fluent 14. I am using the granular model. The transient formulation is the first order implicit. I would like to use adaptive timesteps, but I cannot select it under the Time Stepping Method scroll list. It only has the fixed time step option available. How can I do it? I have found the following info in the manual: Important: Adaptive time stepping is available only with the pressure-based and density-based implicit formulations; it cannot be used with the density-based explicit formulation. In addition, it cannot be used with the discrete phase model, second-order time integration, Euler-Euler multiphase models (Approaches to Multiphase Modeling in the Theory Guide), or user-defined scalars (User-Defined Scalar (UDS) Transport Equations). Is there any way that I can set an UDF or something to adapt the time step? Regards! |
January 23, 2013, 09:58 |
SSL
You can use DEFINE_DELTAT to adapt timestep in density-based mode.
January 24, 2013, 06:29 |
anonymous
DEFINE_DELTAT could be used irrespective of the solver.
You could write your own time step controlling mechanism. |
January 24, 2013, 06:45 |
Bayard Morales
Hi guys - thanks for your help.
I haven't tried to do what you told me, so I may sound a little grumpy, but I have found this in the Fluent UDF manual: DEFINE_DELTAT is a general-purpose macro that you can use to control the size of the time step during the solution of a transient problem. Note that this macro can be used only if Adaptive is selected from the Time Stepping Method drop-down list in the Run Calculation task page in ANSYS FLUENT In my case, the Adaptative option is not available in the drop-down list. Did you guys go to run Euler-euler transient with adaptive? Thanks! |
February 14, 2013, 05:08 |
Bayard Morales
[SOLVED]
In short: I cannot use UDF to change the time-step in Euler-Euler, but using the journal, I can do something similar. I have contacted the Ansys support and this was the answer. ------ If granular model does not allow for adaptive time stepping then you will not be able to use DEFINE_DELTAT. This is because the hook for this function is available only when we select adaptive time stepping. Instead of UDF, you can use a jurnal file for this purpose. A jurnal file is a file which contains commands for Fluent. In journal file, you can put text menu interface (TUI) commands which tells Fluent to do some time steps and then change the time step size. You can find more details on TUI commands in ANSYS14 help guide at this location: // User's Guide :: 2 // 3. Text User Interface (TUI) // 3.1. Text Menu System For example if you want to run the case for 5 time steps using existing timestep size and then want to change the time steps size to 2e-3 sec, here are the commands: ********************* solve dual-time-iterate 5 10 solve set time-step 2e-3 *********************** You can put these two commands in a file with extension as jou and read it in Fluent from File->read -> journal |
November 6, 2015, 06:24 |
B_Kia
Rep Power: 11 |
hi , you can use a journal file and in that change the time step size , it is easy to make one
adaptive-time stepping, time step |
mesh size in Eulerian multiphase flow - liquid/solid mixture | microfin | FLUENT | 4 | December 23, 2016 13:55 |
questions about sensitivity analysis and adaptive timestep | sjtusyc | CFX | 10 | June 21, 2012 09:24 |
ANSYS CFX Adaptive Timestep | aeroman | CFX | 8 | July 25, 2009 06:37 |
Backflow in eulerian multiphase simulation | xeusater | FLUENT | 0 | June 26, 2009 07:50 |
multiphase Eulerian particles | Zbynek | CFX | 5 | September 24, 2008 11:21 |
