How to create a tank which partially filled with fluid? |
February 2, 2013, 11:39 |
#21 |
Philipp
Rep Power: 26 |
At the inlet, did you set the volume fraction of feed to "1" and all others to 0?
Otherwise you will pipe phase 1 as default in, which might be different to feed...
The skeleton ran out of shampoo in the shower. |
February 3, 2013, 04:12 |
#22 |
SSL
Rep Power: 14 |
As I said before, you can use patch to set initial volume fraction of each phase. or use UDF.
February 3, 2013, 07:52 |
#23 |
Rep Power: 13 |
I did set the volume fraction of feed by 1, but same problem occur too.
February 4, 2013, 04:54 |
#24 | |
Philipp
Rep Power: 26 |
Some setting is wrong. Which multiphase model do you use? Please post values / settings you changed in Fluent?
February 4, 2013, 09:13 |
#25 |
Rep Power: 13 |
here is the setting part 1
February 4, 2013, 09:15 |
#26 |
Rep Power: 13 |
here is the setting part2
Thanks |
February 4, 2013, 09:37 |
#27 |
Philipp
Rep Power: 26 |
1) Are you sure about your time step size? With 20m/s at the velocity inlet and dt=60s the fluid will move 1200m each timestep! I am afraid that these settings can't converge... Can you show your residual history? 2) Why don't you set the velocity normal to the surface at the velocity inet, but instead you use a direction vector? EDIT: I just realized that you did some curious things in your calculation settings... Do you know, what all these values mean? Timestep, Number of Iterations, ...
February 5, 2013, 18:24 |
#28 |
Kolela Lela
Rep Power: 13 |
CFD codes are not like Word, Excel or Powerpoint that you can learn to use on your own and it will be fine. When it comes to CFD, you really need to understand what you are doing (your model, fluid dynamics, numerical methods, etc...). And obviously you are lacking a bit of background.
February 6, 2013, 03:53 |
#29 |
Philipp
Rep Power: 26 |
Yes you can!
February 6, 2013, 05:52 |
#30 |
Rep Power: 13 |
This is the first time I'm contact with CFd, I still fresh with it and still got a big room for improvement. I'll spend more to time on it.
Btw, in order to maintain filling rate at 20m/s, what time step and interaction I should use? |
February 6, 2013, 06:52 |
#31 |
Philipp
Rep Power: 26 |
I would: Estimate how far I want to travel the feed during one timestep. Let's say 0.5m.
Now, your time step has to be 0.5m / 20m/s = 0.025s. Then, you set the number of iterations per timestep to 1. This can't work. Since the set of equations is nonlinear, you have to iterate each time step for convergence. I would set the number of iterations to 25 and see how the residuals behave. You could do 10 time steps with these settings and post a picture of the residuals here. Good luck!
February 6, 2013, 10:32 |
#32 |
Rep Power: 13 |
here is the residual result by using time step of 0.05, Number of timestep=10, and interations/time step=25.
February 6, 2013, 10:35 |
#33 |
Philipp
Rep Power: 26 |
This looks bad...
How did you initialize your domain?
February 6, 2013, 10:51 |
#34 |
Rep Power: 13 |
How you differentiate between good and bad residual from the graph?
Sorry, I can't understand your question.. Can u further explain to me? |
February 6, 2013, 10:55 |
#35 |
Philipp
Rep Power: 26 |
It looks like some of the residuals nearly don't change at all during these iterations. This should not happen.
What do you use for initialization? There is a button "initialize" at "Solution->Solution Initialization->" Do you use "hybrid"? I would go for "standard" and set every text box to zero. Then, hit "Initialize". Can you post a picture of your mesh?
February 6, 2013, 11:30 |
#36 |
Rep Power: 13 |
i set all the value as 0 except the temperature=113.
February 6, 2013, 13:35 |
#37 |
Kolela Lela
Rep Power: 13 |
Yes you can, except that you'll spend your time on forums to find clues. When it comes to complex cases, you'll be completely lost and won't be able to tell if your results make sense especially if you do not have validation data.
I still believe that to get the most out of CFD, you need to study it. Everyone can tick boxes but understanding what you are doing is different story. |
February 6, 2013, 13:39 |
#38 |
Kolela Lela
Rep Power: 13 |
February 7, 2013, 04:13 |
#39 |
Rep Power: 13 |
February 11, 2013, 02:55 |
#40 |
Philipp
Rep Power: 26 |
multiphase mixture, partially filled tank, stratification |
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 14:18 |
partially filled tank, evaporation at liq-vap. | prasanth | FLUENT | 5 | July 24, 2013 17:12 |
How to create multiple solid fluid domain? | Mishar | FLUENT | 0 | January 25, 2005 03:05 |
injection of fuel into tank filled with fuel | mujahid | FLUENT | 1 | February 19, 2004 06:36 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
