Reaction simulation in Fluent
Old   February 1, 2013, 19:24
Default Reaction simulation in Fluent
Ankur
ankur_kr is on a distinguished road
Do I need to use UDF (user-defined function) if I have 2 different reactions taking place in different zones in my model. [In my model there is a tube through the center of a Furnace in which combustion occurs. A different reaction takes place inside the tube which uses the heat released by combustion in the furnace]. So, will I need to define a UDF for the reaction in the tube or Fluent allows doing this without using a UDF ?
Someone plz help.
ankur_kr is offline   Reply With Quote
Old   February 1, 2013, 21:38
Ernesto
epc1 is on a distinguished road
Someone plz help.
No, you can easily enable different reactions in different zones via the boundary conditions panel (wall reactions) or in the cell zone panel ( reactions in a fluid zone).
No need for UDF
epc1 is offline   Reply With Quote
Old   February 2, 2013, 00:44
Ankur
Hey thnx
Old   May 28, 2013, 17:51
Ankur
Hi Ernesto,
When I try to run my simulation with 2 different reaction (mechanism) in different regions, I get the following error,
"ISAT cannot be used with two different gas phase mechanisms" .
Do you have any idea about how to overcome this problem ?
I tried to use 'Direct Integration' instead of 'ISAT' using the 'Integration Parameters' dialog box, but the problem persists.
Plz help.
combustion, reaction
chemical reaction modeling using FLUENT wlt_1985 FLUENT 6 April 16, 2014 07:45
RE: In Volumetric reaction, What is unit of pre-exponential factor used in Fluent ? AHJ FLUENT 0 February 18, 2011 06:42
Can dissociation reaction be modeled in FLUENT ? Ked FLUENT 0 February 2, 2006 20:55
Plz help! I can't express this reaction in fluent chang,antony FLUENT 0 September 8, 2002 03:31
New Fluent Remote Simulation Facility Paul Bemis FLUENT 8 July 2, 2002 09:18
