how to simulate drop impact on a solide surface using fluent
Old   February 14, 2013, 15:50
Default how to simulate drop impact on a solide surface using fluent
wbka is on a distinguished road
I am learning to use fluent and i would like to use it to somulate a drop impact on a solid surface . The aim of my work is to study the wetting dynamics ( different phenomenon can occur : spreading of the drop on the surface , bouncing or splashing of the drop) the behaviour of the drop on the surface depends mainly on the contact angle at the contact line ( between the drop and the solid surface) which is determinated by the surface energy of solid and surface tension of the liquid. My idea is to use the VOF model but I as I am a new user of fluent I don't know how to use the contact angle model.
I would be very grateful if somebody could help me .
Thanks in advance
wbka is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Mismatch between Fluent Surface Integrals Report and Surface Line/Rake Tool emlejeen FLUENT 0 March 31, 2010 11:21
