Divergence and High Aspect Ratios
Like Tree7Likes
Old   February 12, 2013, 13:45
Default Divergence problem for steady state compressible flows
victoryv is on a distinguished road
I am doing a external flow simulation on a wall. In my meshing , I have a huge aspect ratios (order of 10^5). I have prism layers along the boundary (first layer thickness around 10^-7). The unstructured mesh outside the boundary layer has parameters- patch conforming,proximity and curvature, min size 10^-4, max face size 0.250m and tet size 0.17m . I am using kw sst model, implicit solver, upwind schemes, green gauss node method. The solution is diverging.
I have tried following methods. But they were of no use.
1. Reducing CFL number. Reduced it upto 0.05.
2. Starting with First order scheme and then switching to 2nd order. The residuals get reduced to 10^-1 after 30 iterations. But when I switch to Second order upwind scheme, they start diverging again.
3.Reducing relaxation factors. Reduced them to 0.3.
4. Refining. I have refined the grid from 0.05 M nodes to 0.2 M nodes.
What else can be done to stop divergence?
Also,
1. Is it a good mesh?
2.I wanted to know if meshes with such high aspect ratios will result in divergence ?
3. Is volume mesh adaption a good option for such meshes?
I would really appreciate if someone would respond.
victoryv is offline   Reply With Quote
Old   February 13, 2013, 18:39
I have a stopped the simulation when it is diverging and saw the contours. The edge shown here( between inlet and bottom wall) has abnormal values.
Is this the reason for divergence?
What could be the problem the mesh or geometry?
I would really appreciate anyone's suggestion.
Old   February 14, 2013, 16:03
I have remeshed it and also redrew the geometry.Also, changed the turbulence parameters at the inlet. The residuals are high but constant for sometime and then start to diverge.Also, I am getting these statements after every iteration.
reversed flow in 392 faces on pressure-inlet 5.
absolute pressure limited to 1.000000e+00 in 9 cells on zone 10009
How can you have reversed flow at the inlet? Any suggestions are welcome.
Old   February 14, 2013, 17:06
PSYMN's Avatar
Simon Pereira
If the inlet or outlet is too close to the area of interest, things can start to reverse. It is common to extend the model by 6 to 10 diameters to ensure that the inlet or outlet is far enough away. Often this is done by extruding the mesh on the inlet and outlet to make a pipe...
You can probably find posts about this elsewhere on CFD-Online...
CFD Online Users Survey
Old   February 14, 2013, 17:09
The inlet and outlet are far apart. My geometry is a windtunnel. Also, can you please see earlier divergence issues I pointed out.
Old   February 14, 2013, 17:10
Far
Sijal
Is it a good mesh?
Without looking at mesh, I am not able to comment.
Normally not. Turn on double precision
Yes. But I prefer to get the good mesh from preprocessor.
Old   February 14, 2013, 17:20
I have turned on double precision.
My mesh quality
Applying quality criteria for tetrahedra/mixed cells.
Maximum cell squish = 9.99997e-01
Warning: maximum cell squish exceeds 0.99.
Maximum cell skewness = 7.60320e-01
Maximum aspect ratio = 2.75799e+06
Its empty wind tunnel. The mesh looks like this. It has boundary layers along the wall at the bottom.
Old   February 14, 2013, 18:13
PSYMN's Avatar
Simon Pereira
The converging duct starts right up near the inlet... It doesn't matter how far apart the inlet and outlet are, it matters how far the inlet and outlet are from things getting interesting...
I think your inlet is too close to your converging section...
Old   February 14, 2013, 18:15
PSYMN's Avatar
Simon Pereira
Also, from your mesh image, I can see that the volume jump between your top prism and the adjacent tetra is huge... The solver probably doesn't like that at all...
You either need more layers so it has time to transition to the larger size...
Or you need a smaller tetra size,
or you need a larger initial size.
Regardless of your Y+ calc, just try out a larger (5 or 10x) initial height and see what happens in the solver.
victoryv likes this.
Old   February 14, 2013, 22:37
You are right. I tried with BL 100x initial size . It did not diverge. The residuals got reduced to 10^-3 and were fluctuating there but by monitoring other parameters i could say it reached steady state. But I need y+ ~1 . So I will try increasing the no of layers, keeping earlier size.
Old   February 14, 2013, 23:16
Far
Sijal
If you need Y+ = 1 , try hexa
Old   February 14, 2013, 23:37
But we do not have inflation layers in hexa right?
Also, do you think we can have proper mesh if we have complex body in the tunnel later on?
I thought unstructured mesh is best for complex geometry. So, is hexa good enough for curved bodies?
Old   February 15, 2013, 00:33
Far
Sijal
Hexa is good for every problem. In Hexa you can get inflation (aka boundary layer) through edge mesh parameters or more conviently through Ogrid. Thats very simple.
Old   February 15, 2013, 02:27
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I am confused. How do pictures from post #2 and #5 fit together? Could you please post a picture of your complete domain, with all surfaces described and also what kind of inlets and outlets you have?
One additional thing: Did you check in Fluent, if "General->Scale..." shows the correct size values?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   February 15, 2013, 09:56
PSYMN's Avatar
Simon Pereira
In the hands of an expert user, ICEM CFD Hexa is great. It is certainly the best way to efficiently capture a boundary layer... It would probably work very well for this model, depending on what you wanted to put into that test section...
But I just wanted to temper Far's comment... on some models (or for some users), hexa is not worth the hassle ;^), which is when tetra/prism or polyhedral meshing kicks in.
Far and victoryv like this.
Old   February 15, 2013, 16:42
They are the same. In #2 only bottom and inlet are shown where I found abnormal values. The flow is in +x direction. BC are bottom wall, pressure inlet , pressure outlet, other faces are taken as symmetry. It is actually half section of a wind tunnel.I have also checked the scaling. They are right.
Old   February 15, 2013, 16:54
I have been using unstructured grids in 3D since I started using Fluent. I have never used ICEM CFD. Though I have heard its really good for meshing. But I read somewhere that its features have already been added in Ansys Meshing application in workbench. That is the reason I haven't learned it . I will probably give a shot at ICEM CFD and hexa once I finish this work.
Old   February 15, 2013, 17:47
PSYMN's Avatar
Simon Pereira
A lot of the ICEM CFD technology has been exposed... Even ICEM CFD hexa is in ANSYS Meshing as "MultiZone".
But MultiZone is really an automated, almost patch conforming bottom up version of ICEM CFD hexa... Very different from the top down, powerful, flexible tool that ICEM CFD users love, but a great tool in its own right.
Old   February 16, 2013, 13:45
Philipp
1) So the left of the yellow part is the inlet and the right yellow part with the little teal area shows the bottom?
2) It looks like you use energy equation. What are your boundary conditions?
3) Does your simulation converge without the temperature stuff?
4) So top is also symmetry? How can this curve be symmetric?
5) How can this be "half of" something, when you have 3 of 6 faces with a symmetry boundary condition?
Again: Please post an clearly arranged picture of your domain and mark all faces with their meaning.
Old   February 16, 2013, 17:05
Please see the pic. I have added the names.
1.Yes, you are right.
2.Yes, I am using energy equation. It started to diverge again. I am using compressible flow.
3. The left is symmetry - half section plane. The other two boundaries are symmetry due to slip condition.
4.Bottom wall is no-slip wall and other boundaries are pressure inlet and pressure outlet.
multiphase flow, quick divergence of contuinity eq violet FLUENT 8 February 16, 2016 05:32
[ANSYS Meshing] Very high aspect ratio zxin ANSYS Meshing & Geometry 12 August 16, 2011 09:49
Divergence detected in AMG solver:species-0 arulmurugan Fluent UDF and Scheme Programming 0 February 15, 2011 04:22
non zero divergence for incompressible flow! Pascal_doran OpenFOAM Running, Solving & CFD 17 September 21, 2010 10:22
About divergence for help! xhliu1 Siemens 2 April 7, 2005 03:53
