NIST model in Ansys-Fluent
Old   February 14, 2013, 04:52
Unhappy NIST model in Ansys-Fluent
Shuvayan Brahmachary
b.shuvayan is on a distinguished road
I wanted to simulate R134a in Ansys Fluent in its super critical phase and hence enabled NIST real gas model for the same.
An annular pipe is made and meshed in workbench where inner wall is heated and outer wall is made adiabatic and the flow is made upward in the annular pipe with boundary conditions as follows:-
inlet mass flow rate:- 0.16Kg/m2s
inlet temperature :-423K
Pressure outlet :- 5Mpa
and inlet pressure :- 5Mpa
heat flux :- 25kW/m2
The temperature and pressure are above the critical point.But the error which I am getting is :-
REFPROP_error(202) from function:tprho (density)
liquid iteration has not converged for T= Nan K,P= 5.0000Mpa,rho?(last guess)=Nan mol/L,compositions =1.0000
Kindly help me....
Thanking you.
b.shuvayan is offline   Reply With Quote
Old   April 3, 2013, 11:02
Johnson
microwinner is on a distinguished road
Send a message via MSN to microwinner
Hi, is your problem solved? Recently, I met this problem? But I avoided it by changing the boundary condition. However, in this case, it not my original situation. I am very interested in your results. Thanks
Originally Posted by b.shuvayan View Post
Kindly help me....
Thanking you.
microwinner is offline   Reply With Quote
nist
Seeking Macroscopic Particle Model in Fluent bzhang7 FLUENT 3 June 25, 2022 17:54
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
gambit in Ansys FLuent 13 saharesobh FLUENT 0 August 1, 2012 15:30
how can export model from fluent to ansys abcd19 ANSYS 0 June 18, 2011 15:15
ansys fluent les model bene Main CFD Forum 0 June 7, 2011 10:45
