what is meant by Operating Pressure in Fluent?
Like Tree8Likes
Old   March 9, 2013, 03:51
Exclamation what is meant by Operating Pressure in Fluent?
Mifrah Ali
mifrah is on a distinguished road
hello all,
i am a new user in Fluent.
i want to know what exactly is meant by operating pressure in fluent?
its default value is 101325 pa, is it atmospheric pressure? but sometime we also assume 0 as operating pressure, its making me feel dizzy....
what will be the operating pressure in 10 meter depth of a pool?
mifrah is offline   Reply With Quote
Old   March 9, 2013, 05:40
blackmask will become famous soon enough
It depends on how you model the density. It is always valid to set the operating pressure to (approximately) the mean pressure of the flow field. But it is only when you model the density using incompressible ideal gas law, or you are dealing with low-Mach-number compressible flow that the value of operating pressure is important.
The operating pressure is not used if the density is modeled to be constant.
You should check the Fluent user manual because it has more detailed and accurate description of the operating pressure.
blackmask is offline   Reply With Quote
Old   March 9, 2013, 12:38
Mifrah Ali
in my case density is constant so it means i can take operating pressure as zero??????
Old   March 9, 2013, 15:16
Default dear ....
farzadpourfattah
farzadpourfattah is on a distinguished road
when you set pressure of operation condition 0 pascal, you prevent reverse flow in your domain.
farzadpourfattah is offline   Reply With Quote
Old   March 10, 2013, 01:15
Yes. You can set operating pressure to any value because it is not used in case of constant density.
chaitanyaarige likes this.
Old   March 12, 2013, 14:02
Mifrah Ali
Thank you
Old   June 8, 2013, 12:13
FHydro
flow_CH is on a distinguished road
what is that value in VOF model? (water+air)
flow_CH is offline   Reply With Quote
Old   June 15, 2013, 11:27
Default vof
farzadpourfattah
if you set value of water 1 in a zone,value of air will be 0 at same zone.
Old   June 6, 2016, 12:57
rizky djon hansemit
rizkydjonhansemit is on a distinguished road
hi blackmask,
can you tell us how do we know the mean pressure of the flow field in fluent. in my case i simulate 2d vawt in a wind tunnel. is there any consideration when we want to specify certain value of operating condition in fluent for incompressible ideal gas air. what about reference pressure location? its default value is [0,0,0]. how to specify the right reference pressure location in our simulation? please help us
rizkydjonhansemit is offline   Reply With Quote
Old   June 12, 2016, 17:49
rizky djon hansemit
is there any help?
Old   September 20, 2017, 00:07
Parag Mangave
paragmangave is on a distinguished road
i am trying to simulate flow over blunt bodies my conditions are 100500pa, 303k,1.1551 density, what should be my operating pressure and guage pressure?
paragmangave is offline   Reply With Quote
Old   September 20, 2017, 09:01
pakk will become famous soon enough
You choose!
Real pressure = operating pressure + guage pressure.
If you want the real pressure to be 100500 Pa, you can set operating pressure at 100500 Pa, and then at the boundary set 0 Pa.
Or set the operating pressure at 100000 Pa, and the pressure at the boundary at 500 Pa.
Or the operating pressure at 0 Pa, and the pressure at the boundary at 100500 Pa.
Physically, it is all the same. Exactly the same, identical.
Only numerically, it is helpful to have smaller numbers for guage pressures, so put your operating pressure close to the 'average' pressure in your system. Extreme example: don't set your operating pressure at 10000100500 Pa, and your guage pressure at -10000000000 Pa, you will get numerical problems.
pakk is offline   Reply With Quote
Old   September 20, 2017, 09:11
Parag Mangave
Also is prism layer generation necessary for supersonic speed?.
Without using prism layer mesh can I use k omega or k epsilon turbulence model?
Old   October 26, 2017, 05:47
Rouven
ArcticMonkeyyy is on a distinguished road
A Question regarding this Operation Pressure:
I have a low-Mach-No. Simulation and i know that the pressure inside my geometry should be s.th. about 7-8bar. So i set the operation Pressure to 7 bar. As result I got a pressure value of 1bar in the interior. So does this mean that I have to add 1 bar to the operation pressure to get the "real" value of pressure?
Actually I have 1 bar beyond the inlets and outlets. Does this operation pressure influence my "outside"-conditions? So if I want 1 bar outside, do i have to set the pressure boundary condition to -6bar because 7bar minus 6 bar is 1bar?
Best regards
ArcticMonkeyyy is offline   Reply With Quote
Old   March 9, 2018, 06:11
Hongyang Chen
chenhongyang is on a distinguished road
“ANSYS Fluent provides a “floating operating pressure” option to handle time-dependent compressible flows with a gradual increase in the absolute pressure in the domain. This option is desirable for slow subsonic flows with static pressure build-up, since it efficiently accounts for the slow changing of absolute pressure without using acoustic waves as the transport mechanism for the pressure build-up.
Examples of typical applications include the following:
1.combustion or heating of a gas in a closed domain
2.pumping of a gas into a closed domain
Limitations:
The floating operating pressure option should not be used for transonic or incompressible flows. In addition, it cannot be used if your model includes any pressure inlet, pressure outlet, exhaust fan, inlet vent, intake fan, outlet vent, or pressure far field boundaries.“
From ANSYS FLUENT help document.
chenhongyang is offline   Reply With Quote
Old   May 11, 2018, 01:26
BHOLU KUMAR
BHOLU is on a distinguished road
Suppose I have set intet pressure = 405300 Pa (Fluent solver)
Outlet gauge pressure = 4000 Pa
Operating pressure = 0 Pa
Then A/C you Real Pressure at inlet = 405300+0 = 405300 Pa
outlet pressure gauge pressure = 4000 + 0 = 4000 Pa only ?
BHOLU is offline   Reply With Quote
Old   May 11, 2018, 05:31
Kushal Puri
Kushal Puri is on a distinguished road
Yes if you are using 0 operating pressure the you have to apply absolute value of pressure at outlet also
Kushal Puri is offline   Reply With Quote
Old   May 11, 2018, 06:16
BHOLU KUMAR
Thank you Kushal.
Old   May 16, 2018, 09:14
Default Operating pressure
  #19
Nitesh Kumar
dexter is on a distinguished road
Hi Bholu,
Did you get the desired result.
dexter is offline   Reply With Quote
Old   December 4, 2018, 05:59
Fab
Federer83 is on a distinguished road
Hi all,
Thanks for all your answer. What about if i want to calculate in a bend pipe the pressure losses and the poutlet is 10bar in a incompressible fluid?
From what i understood:
a) operating pressure= 10 bar
b) gauge pressure = 0 bar?
Correct?
Why my pressure in CFD post is not considering the operating pressure?
Thanks
Federer83 is offline   Reply With Quote
fluent, operating pressure
How to give pressure inlet in Fluent Vijayaragavan Main CFD Forum 1 December 17, 2007 09:40
Different kinds of pressure in FLUENT Mattia FLUENT 0 October 22, 2007 08:52
floating operating pressure and monitors force Lavastre jeremie FLUENT 2 September 7, 2007 08:10
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
