March 28, 2013, 16:56 |
Questions on a pressure profile
Rep Power: 17 |
I have some questions on a pressure profile obtained from a simple 2D laminar pipe flow.
Please look into the attached .jpg image of the pressure contour Could some one please provide clarifications to the following questions I have - As the flow proceeds from the inlet, there is a gradual pressure drop. Could this be solely attributed to the frictional losses due to wall shear ? The bernoullis theorem doesn’t seem to hold good here because it is expected that the pressure should increase as the cross sectional area increases for the flow, however a pressure drop is witnessed from the plot. Could you please explain the limitation of bernoullis theorem in this case
Best regards, Santhosh. |
March 29, 2013, 04:59 |
Rep Power: 17 |
Sorry this question is rather academic. I've gone through some books and found that it's a case of Poiseuille flow. Bernoullis theorem is not applicable here as it is a viscous flow (the flow has a very low reynolds number so the viscous effects dominate the inertia). Yes the pressure drop is due to the viscous shear , the shear stress acts in a direction opposite to the flow and a pressure drop from inlet to outlet is required to counter balance this.
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
Two fundamental questions about icoFoam while updating the velocities and pressure | dbxmcf | OpenFOAM Running, Solving & CFD | 6 | April 12, 2016 16:05 |
Few simple questions concerning boundary conditions (pressure) | milos | OpenFOAM Pre-Processing | 1 | March 21, 2009 07:08 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
