Double Tube Flow
Old   March 28, 2013, 17:25
Default Double Tube Flow
bbasal is on a distinguished road
hi;
i want to solve a natural convection in a double tube. water flows thorough the innert tube, and there is air in the annuli (and there is a natural convetion there). i can not set up the problem because there is an interface between two tubes. i send a figure in attachment about geometry and boundary conditions.
if i select interface boundary condition for "interface" fluent says "WARNING: mesh check failed.
"To get more detailed information about the mesh check failure
increase the mesh check verbosity via the TUI command
/mesh/check-verbosity. "
if i select wall boundary condition for "interface" then fluent creats a interface-shadow. i select coubled under "thermal conditions" then define other boundary conditons.
when i came the initialize section there is already "-1.#IND" in the velocity inlet and all zones. i delete that and put actual values. but fluent could not solve the problem, say "divergence detected in AMG solver: x-momentum"
what can i do, how can i solve this problem i defined.
thanks already
sorry for poor english
bbasal is offline   Reply With Quote
problem in toposet Ahmed Khattab OpenFOAM Pre-Processing 27 March 3, 2023 21:12
Outlet boundary condition for a heated tube flow JinBiao OpenFOAM Running, Solving & CFD 0 July 28, 2012 03:56
concentric/tube in tube counter flow HX ask123 FLUENT 0 May 24, 2010 06:41
Flow Through Bend tube of circular c/s applemango FLUENT 0 March 8, 2010 04:52
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
