Warning: couldn't find neighbor across sliding interface ... reflecting
Old   April 3, 2013, 04:32
Default Warning: couldn't find neighbor across sliding interface ... reflecting
Astio Lamar
asal is on a distinguished road
Hello!
I run a case in HVAC system. first I solve the flow until achieved converge solution. then I inject some particle throw certain surfaces. By starting DPM iteration I got the following warnings"
Warning: couldn't find neighbor across sliding interface 17 type 24, reflecting.
Warning: print buffer exceeded.
Do anybody knows what is the problem?
asal is offline   Reply With Quote
Old   April 4, 2013, 05:38
SSL
msaeedsadeghi is on a distinguished road
The problem is with your mesh.
msaeedsadeghi is offline   Reply With Quote
Old   April 4, 2013, 07:59
Astio Lamar
Well!!
No, as I mentioned the mesh has a great quality and I got converge solution. I found the problem by getting help from ANSYS company. they found that those error messages are known to be an issue in Fluent 14.
Old   October 24, 2016, 09:25
Default And the solution was...??
HHOS is on a distinguished road
Hello asal!
The thread is very old now, but I am facing the same problem here.
I wonder if you could please share the solution to the problem.
Thanks in advance!
HHOS is offline   Reply With Quote
How to use setField to create sphere sega OpenFOAM Pre-Processing 38 January 13, 2022 00:39
[swak4Foam] installing funkySetFields prapanj OpenFOAM Community Contributions 65 October 8, 2015 17:46
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
