Modelizing two infinite parallel planes
Like Tree2Likes
  • 1 Post By oj.bulmer
Old   April 2, 2013, 09:39
Exclamation Modelizing two infinite parallel planes
Hakim Mkacher
kiurigan is on a distinguished road
I want to know if there is any trick to modelize infinite geometries in fluent like two infinite parallel planes in 2D?
kiurigan is offline   Reply With Quote
Old   April 3, 2013, 11:08
OJ
oj.bulmer will become famous soon enough
You can do it with the use of symmetry and streamwise-periodic boundary conditions.
OJ
kiurigan likes this.
oj.bulmer is offline   Reply With Quote
Old   April 4, 2013, 07:40
Hakim Mkacher
Thanks for reply.
But I can't use symmetry because I have a pressure gradient (which ensures the flow) and I can't use the periodic boundary condition because the two planes are in different temperatures and the use of periodic boundary condition obligates that all wall boundaries must be at the same temperature!! (see documentation here:
https://www.sharcnet.ca/Software/Flu...hxfer-restrict)
Old   April 4, 2013, 08:32
OJ
Be careful with the interpretation of the words
1) Streamwise periodic conditions do allow temperature and pressure drop in streamwise direction. You need to select a domain length in streamwise direction such that these drops are same for the next domain of same length.
http://jullio.pe.kr/fluent6.1/help/html/ug/node337.htm
2) "Constant wall temperature" doesn't mean all walls should be at same temperature. It means on any particular wall, the temperature everywhere should be the same, i.e. uniform without any profiles. But the temperatures of the streamwise-periodic boundary conditions can vary:
https://www.sharcnet.ca/Software/Flu...c-hxfer-theory
3) I mentioned symmetry, since in 2D case with FLUENT, the domain itself becomes a symmetry boundary conditions, in whole perspective, with the boundaries perpendicular to the flow being streamwise periodic. In CFX, you have to use a thick domain to simulate the same 2D case, where you would use the symmetry boundary conditions to the boundaries parallel to the flow and streamwise periodic boundary conditions to the boundaries that are perpendicular to the flow.
OJ
Old   April 4, 2013, 09:51
Hakim Mkacher
Thank you so much. It seems that I misunderstood this sentence "all walls must be at the same temperature (profiles are not allowed)"!!
geometries, infinite, parallel, planes
Running in parallel Djub OpenFOAM Running, Solving & CFD 3 January 24, 2013 16:01
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 15:52
free convection between 2 infinite parallel plate runny craven Main CFD Forum 2 September 19, 2001 05:45
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
