Faxen Correction in DPM Body Force
Old   January 26, 2007, 06:24
Default Faxen Correction in DPM Body Force
Davis Yohanes Arifin
I have difficulty in incorporating Faxen correction for my particle tracking code since it has the second gradient of velocity vector. I understand that I need to include "surf.h" and access the cell's fluid variable via RP_CELL and RP_THREAD; but, when I try to interpret the UDF, it shows me an error message in line 35 of "surf.h". Is it true that DPM must be compiled, not interpreted?
Thanks.
Old   January 26, 2007, 07:59
Default Re: Faxen Correction in DPM Body Force
Sujith
yes, most of the dpm macros contains the structure reference ->, for this the udf should be compiled. Interpret will not work in this case.
Old   December 5, 2017, 03:18
trbprnz is on a distinguished road
Hi Davis, did you finally implement your Faxen correction? If so, can you share your UDF? Thx, Alex
trbprnz is offline   Reply With Quote
Step-by-Step Procedure for DPM body force wwt650420 FLUENT 10 March 22, 2017 10:03
Force can not converge colopolo CFX 13 October 4, 2011 22:03
DPM Body Force Sandilya Garimella FLUENT 1 April 8, 2008 03:30
Large varying body force vs. Rhie-chow correction john Main CFD Forum 1 May 23, 2007 02:27
DPM body force Doubt Sandilya FLUENT 0 May 21, 2007 13:32
