FLUENT 14 - Periodic boundary conditions
Like Tree3Likes
  • 1 Post By zhenglun.wei
  • 1 Post By RodriguezFatz
Old   April 10, 2013, 10:19
Default FLUENT 14 - Periodic boundary conditions
Marco
msatrustegui is on a distinguished road
Hi everyone,
I'm trying to simulate a solid cilinder situated inside a bigger cylinder, which is filled of air.
The inner cylinder has an energy source, so it warms and the heat is evacuated from the inner to the outer cylinder by natural convection.
Here comes the question, I'm trying to simplify the model by representing only part of the full model (only 30º out of 360º). How do i have to model the side walls?
When i define them as symmetry, i do not get the result i expect. The temperature along the tangential direction should be constant, however it gets colder at the extremes. Do i have to define the walls as periodic instead of symmetric? How do i define the periodic condition?
Thanks for your help.
PD: I've attached an image of the results i'm getting with symmetry conditions in the side walls.
msatrustegui is offline   Reply With Quote
Old   April 10, 2013, 12:31
zhenglun.wei is on a distinguished road
You may have two ways to do it:
1, define the periodic BC: you need to have some special treatment while generating the mesh for the boundary that you want to enforce the periodic BC. I'm sure that ICEM CFD has an approach to do that. However, different meshing package has difference way. You'd better check the manual.
2, use the axis-symmetric simulation: if your model is axis-symmetric, you can generate a 2D domain and use axis-symmetric simulation in FLUENT. It simplifies the problem a lot. Check FLUENT manual for: Modeling Axisymmetric Flows.
hope it helps,
Alan
msatrustegui likes this.
zhenglun.wei is offline   Reply With Quote
Old   April 11, 2013, 03:50
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi msatrustegui,
1) Where is the heat source? At r=0 ?
3) The "red" body in your picture is the solid, and the transparent part is the air, right? So there is air at the top, bottom and side-wall of the inner cylinder?
2) Why do you simulate this in 3d? Isn't it fully cylindrical symmetric?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   April 11, 2013, 03:56
Marco
Originally Posted by RodriguezFatz View Post
Hi msatrustegui,
Thanks for answering,
1) The heat source is constant all over the body.
2) You're right. The solid cylinder is surrounded by air.
3) I'm simulating it in 3D because this is a simplified model, the original is periodic every 30 degrees.
Any ideas to make it periodic?
The only software i have is Ansys meshing and i don't know how to define the periodic boundaries there. In Fluent the only way i found is using TUI, but it doesn't work very well..
Old   April 11, 2013, 04:10
Philipp
Alright. You have one problem: Normally, you should try to get a conformal mesh at the two faces that you want to become periodic. In your case, I don't see how that works, because your inner body goes to r->0. Thus, you can not just sweep the surface mesh for 30°...
Anyway you have to create a non-conformal periodic mesh. In my fluent help version this is explained under "5.4.4. Using a Non-Conformal Mesh in ANSYS FLUENT".
Try to get this running. Unfortunately, I never did that and can not help you...
Old   April 12, 2013, 04:33
Marco
I finally found a way to do it. It's explained in another thread of this forum. Here is the link:
http://www.cfd-online.com/Forums/fluent/105041-fluent-periodic-boundary-condition-solved-tutorial.html
Thanks for your time!
Old   April 12, 2013, 04:43
Philipp
But isn't the tutorial you mentioned for conformal meshes? Or did Ansys Meshing create a conformal mesh?
Old   April 12, 2013, 04:50
Marco
As you said, the link I posted is for conformal meshes. The thing is that i can simulate my model using conformal and also non-conformal meshes. The problem was i could not define periodic walls in anyway. However, the tutorial I linked worked very well.
Old   March 20, 2016, 11:17
Muhammad Furqan Ali
furqanrk is on a distinguished road
Send a message via Skype™ to furqanrk
Dear expert.. I have to use Superficial gas velocity 0.0016 m/s. But In fluent we have to put Velocity Magnitude at VELOCITY INLET boundary conditions.( INLET VELOCITY) How can I calculate INLET GAS VELOCITY form superficial gas velocity??? ( Reactor dimensions are 20*5*50 cm W*D*L and inlet dimensions are 2.4*1.2 L*D )
furqanrk is offline   Reply With Quote
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
Radiation interface hinca CFX 15 January 26, 2014 17:11
Use periodic boundary conditions with DES - Urgent! HeKhalil Main CFD Forum 4 November 23, 2012 11:31
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
