[Fluent]Sinking of non melted material during phase change
Old   November 20, 2013, 10:01
Default [Fluent]Sinking of non melted material during phase change
Tom Marquardt
TomM is on a distinguished road
Hey guys,
I would like to simulate the melting behaviour of a paraffin in a horizontal cyclindric container.
In the middle of the container streams water with a defined temperature T(0). The heat is transfered trough the tube wall into the pcm causing it to melt.
I got this running so far but I would like to expand this modell.
Is it possible to implement the sinking of the non melted material? If the water stream enters the cylinder from the bottom the material which is still solid would sink at some point.
I attached some pictures of the modell.
Thanks in advance! I hope I made my point clear
TomM is offline   Reply With Quote
error message cuteapathy CFX 14 March 20, 2012 06:45
water 2 phase, Change from hight to low temp panuwat FLUENT 0 June 19, 2006 08:50
Solid Phase change material qiulan Siemens 0 June 5, 2006 15:30
Phase change process Sang-jin Lee Siemens 5 December 5, 2001 05:17
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
