How to set the boundary condition of Pressure Outlet
Old   April 19, 2013, 17:29
Question How to set the boundary condition of Pressure Outlet
Yiyuan YONG
justeyong is on a distinguished road
Hi there,
I have a simple geometry, which is a vertical tube. I know the inlet velocity and , and the pressure at outlet.
The turbulent model is standard k-epsilon. I set the inlet as velocity inlet with values of U, P, k, and epsilon.
However, when I set the outlet boundary condition, Pressure Outlet, the only thing I know is the pressure.
My question is how to (or do I need to) set the backflow turbulent k and backflow turbulent epsilon?
justeyong is offline   Reply With Quote
Old   April 20, 2013, 04:06
Esteban
valio is on a distinguished road
Set the same values of k and e for your pressure outlet condition.
You can launch your computation, save results and launch a computation with other values of k and e and see the influence, but I think it does not really matter.
Valio
valio is offline   Reply With Quote
Old   April 20, 2013, 09:58
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by justeyong View Post
Hi there,
These values are used only when there is reverse flow I guess. Otherwise only pressure is required at outlet.
Far is offline   Reply With Quote
Old   April 20, 2013, 14:31
Yiyuan YONG
Originally Posted by valio View Post
Valio
Thanks very much!
pressure outlet condition setup halfblood@SYSU Main CFD Forum 0 March 15, 2013 22:35
How to Set Pressure Outlet Boundary Condition freeday Fluent UDF and Scheme Programming 1 August 30, 2012 11:49
Pressure outlet boundary condition fluent_newbie FLUENT 0 December 1, 2011 23:51
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
