Erosion modelling in slurry flow through pipelines
Old   May 1, 2013, 04:40
Post Erosion modelling in slurry flow through pipelines
piyush singh
Piyushsingh is on a distinguished road
I have already explored the option to solve erosion model and also solved the erosion rate on a nozzle of 3.6mm inlet dia and 0.8 mm of outlet dia. Now i am working on a model that is a big container of inlet dia 250 mm and 31 mm but i am not getting the result though i am solving it with same procedure. I want to ask is there any changes required in erosion modelling procedure or the values that i am taking if the inlet and outlet size increases suddenly like in this case.
thanks
Piyushsingh is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Models for Erosion in Slurry Pipe leonozx FLUENT 1 May 25, 2011 10:28
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
modelling blood flow in arteries with starcd sara Siemens 5 April 10, 2007 09:17
Modelling flow around a ship's hull using vof Manoj Kumar FLUENT 0 February 26, 2005 16:22
