Supersonic free jets from CD nozzle
Old   April 22, 2013, 11:12
Default Supersonic free jets from CD nozzle
Naveen S Das
naveensdas is on a distinguished road
Hi Friends !!
I am new to Fluent.. I am trying to simulate a 2D supersonic free jet from a Convergent Divergent nozzle.This is how i set up my problem
I am using 2d axisymmetric, steady implicit formulation. Operating pressure=98950Pa. I am expecting oblique shocks at the exit. I went for a Density based solver and realizable K-e Model for turbulence.
Nozzle Inlet pressure=465250Pa (Pressure Inlet B.C). The upper part of the nozzle, I went for wall b.c and the right end of the domain is pressure outlet and the bottom part is the axis.
My domain is 22D in axial direction and 5D in the radial direction
For Left and the upper part of my domain, I had initially gone for pressure inlet B.C with gage pressure=0. But I started to get warnings “temperature limited to 5000K”. I found out that the sharp edge was giving the problem. I refined the mesh close to the sharp edge. But still divergence occurred. Then I got a suggestion from a friend to change the left and upper domain b.c to pressure outlet. With that, I was not having that much a problem with sharp edge. But still my residuals are diverging after initially showing a downward trend.
I even started with a courant number of 0.05 and reduced the URFs. I used first order difference schemes. But I cannot get a converged solution..
Is there any problem with the B.C’s or turbulence model? Please help me..
Thanks in advance !!
Naveen
naveensdas is offline   Reply With Quote
Old   April 22, 2013, 13:26
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
can we take a look at your mesh first ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 22, 2013, 22:42
Naveen S Das
Hii Ali
Thanks for replying.. !! i am posting the screen shot of my mesh. will send you the dbs file by mail if you want
Old   April 23, 2013, 00:22
Chris, Kam
cartman is on a distinguished road
did you set the initial pressure as "0"?
or outlet pressure as "0"??
because, what I know is that you can't get exact solution of rarefied gas dynamics with fluent
sorry about my weird English, I'm not good at this language :z
or you can set the nozzle-inlet condition gradually
(set 1 atm for the condition and iterate, set 1.2 atm when the changes of residuals seeme stable, .... set real condition)
cartman is offline   Reply With Quote
Old   April 23, 2013, 00:27
Naveen S Das
Hii Chris,
I have given operating pressure as 98950 Pa (which is the ambient pressure) .. so if i give the gage pressure as 0, then is it a problem?
Old   April 23, 2013, 00:39
Chris, Kam
I'm not sure, but.. I heard that 0 pa for operating pressure is good for compressible flow
(I always set like that)
Old   April 23, 2013, 02:04
Naveen S Das
Thanks Chris ..!!
I will try with operating pressure=0.. so i guess i have to keep my initial guess pressure at 98950 Pa.. am i right?
Old   April 23, 2013, 02:41
Chris, Kam
keep the initial condition as ambient will be nice
Old   April 23, 2013, 03:05
Naveen S Das
Hii Chris !!
I have tried to run the simulation with operating pressure=0 and setting initial guess pressure as ambient.. i also went for first order discretization schemes to begin with and a courant number of 0.5.. residuals were decreasing to 5*10^-2.. but then i get the warning "time step reduced in cells" and the number of such cells goes on increasing and with that residuals too started increasing...
Old   April 24, 2013, 12:49
Naveen S Das
I would also like to know if my B.Cs are correct..?
Old   April 25, 2013, 01:15
Chris, Kam
I think so,
If you don't mind, could you pass your case file?
Old   April 25, 2013, 02:38
Naveen S Das
I think so,
Thanks Chris !! shall i mail it to you?
Old   April 25, 2013, 04:49
Chris, Kam
sure,
hdkam@pknu.ac.kr
Old   April 25, 2013, 06:00
Naveen S Das
Hii Chris
i have mailed you the case file
Old   May 2, 2013, 12:07
Naveen S Das
Hii Chris,
Could you identify any mistakes?
LES supersonic free jet martyn88 OpenFOAM 22 April 17, 2015 06:00
Supersonic turbulent free jet LES martyn88 OpenFOAM Running, Solving & CFD 7 July 1, 2013 10:51
reversed flow in over-expanded supersonic nozzle imnull FLUENT 0 March 28, 2013 10:48
C-D nozzle supersonic jet boundary Gland FLUENT 4 May 24, 2012 00:25
some questions for supersonic channel nozzle goldenland FLUENT 2 November 4, 2007 21:18
