boundary conditions
Old   May 8, 2013, 03:14
Default boundary conditions
yusuf gara
khodam is on a distinguished road
hi
how i can determine boundary conditions for this system :
a reactor contain on agitator , for mixing
khodam is offline   Reply With Quote
Old   May 8, 2013, 12:26
Brandon Hathaway
Hathaway is on a distinguished road
Send a message via ICQ to Hathaway
I would suggest you take a look at the tutorial example found in Chapter 23 of the Fluent Tutorial guide. It describes defining cell zone conditions to represent an impeller.
The actual impeller profiles they use are based on measured data reported in an academic paper, so you'd want to check out that reference and see how applicable it would be for your usage, but the general procedure can still be followed, you'll just need to adjust the profile values based on the impeller system and size you'll be modeling.
If you have access to the ANSYS customer portal, then see: Chapter 23: Using the Eulerian Multiphase Model for Granular Flow
Hathaway is offline   Reply With Quote
Old   May 9, 2013, 06:46
yusuf gara
thanks so much.
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
