how to calculate the turbulent input parameters for boundary conditions?
Old   May 17, 2013, 02:43
Default how to calculate the turbulent input parameters for boundary conditions?
nvtrieu is on a distinguished road
Hi every ones,
I am doing simulation for 3D NACA 0012 wing.
I use 3 different tubulent models:
k-e realizable
k-w SST
SA
The boundary conditions are:
Velocity inlet
Pressure outlet
wall
My question is how to set the turbulent parameters for the input and output bcs such: k,e,I,L,...
I also want to calculate the lift and drag coefficient acting on the wing surface. But I am not sure about the reference values such: area, length. I set the reference area=chord*span and the reference length=chord. Is this right or wrong?
Thanks you
nvtrieu is offline   Reply With Quote
Old   May 17, 2013, 02:48
I want to compare with experimental data from NASA experiment. So, how can I know these turbulent conditions?
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
How to calculate turbulent structure? mohammad ANSYS 0 December 11, 2012 23:55
giving spacially varying input conditions to Kiva CHANDER SHEKHAR SHARMA Main CFD Forum 0 October 6, 2005 09:33
Turbulent Mass Injection Boundary Conditions B. Laubacher Main CFD Forum 6 October 16, 1999 11:56
Initial Conditions in unsteady turbulent flow Z. Zeng Main CFD Forum 5 April 28, 1999 17:38
