centrifugal compressor analysis
Old   June 4, 2013, 05:34
Post centrifugal compressor analysis
farzad
farzadmech88 is on a distinguished road
Dear all
this is Farzad, and I want ti simulate a centrifugal compressor, but I have some problems.
I use blade-generator and I exported it to design-modeler,I mesh it, now I face a problem in fluent(solver) sectio.
1- I use MRF , but I don't know the exact rotation direction, is it (Z) or (-Z)?
2- in tutorials they use oressur inlet and pressure outlet, why? do we must know these quantities?
3- after all when I run calculations, after few iterations I observe REVERSED FLOW.
I appreciate your helps in advance.
Farzad
farzadmech88 is offline   Reply With Quote
Old   June 4, 2013, 05:39
farzad
this is my mail problem:
I am doing CFD analysis of compressor in FLUENT.
but i am facing the problem of REVERSED FLOW at inlet as well as outlet with Pressure outlet condition.
i am using density based solver.Is it appropriate??
If i am using IDEAL GAS as fluid then it shows very large values of ranges pressure, temperature and velocity.""
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
Autoblade centrifugal pump template mahdi balali Fidelity CFD 3 February 18, 2014 08:56
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 06:07
centrifugal pump and centrifugal fan Mangesh Main CFD Forum 3 January 3, 2006 11:21
