Heat transfer through pipe wall
Like Tree1Likes
  • 1 Post By delaneyluke
Old   June 4, 2013, 10:51
Default Heat transfer through pipe wall
sheikh
billue123 is on a distinguished road
I am designing a gas water heater. i have modelled and meshed the whole structure. unfortunately the flue gases which are at a temprature of 750K do not seem to heat up the water through the wall. the temperature of the water remain at 303K at 2.5sec to 1min. Please help me in this regard kindly. what options in the wall must i select "on" so that heat is transfered through it to the water
thanks
billue123 is offline   Reply With Quote
Old   June 4, 2013, 14:58
delaneyluke is on a distinguished road
Your walls (between the flue gas and pipe and water) should be defined as coupled walls
Regards
Luke
billue123 likes this.
delaneyluke is offline   Reply With Quote
Old   June 4, 2013, 15:41
sheikh
how can i define it as couple wall? in the fluent on the option of wall comes?
Old   June 4, 2013, 16:59
Yes it is an option in wall BC screen, i think under the Temperature tab
Regards
Luke
Old   June 5, 2013, 03:15
sheikh
unfortunately i can not find such option. the options available to me are as follow in the picture shown.kindly please help
Syntax errors with Thread Types and Wall Heat Transfer calculation jcespada Fluent UDF and Scheme Programming 2 March 16, 2012 02:23
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
Pipe Flow Heat Transfer Saima CFX 5 January 30, 2011 16:41
Heat Transfer in a pipe flow(hot air) Saima Main CFD Forum 0 January 17, 2011 07:08
Wall heat transfer coefficient (HTC) problem Mohamed khamis CFX 1 January 15, 2010 23:12
