mixing tank
Old   June 22, 2013, 13:29
Default mixing tank
Mikel Mendibe
wemendibe is on a distinguished road
If I put 100 rpm rotational velocity to the impeller in the mixing tank it converge, but if I put 500 rpm it does not converge, do anyone knows why??
I put in viscous model k-epsilon RNG, because it is turbulent, I can say if anyone knows all the steps that I have.
Thank you
Mikel Mendibe
wemendibe is offline   Reply With Quote
Old   June 23, 2013, 04:27
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
At off-design conditions you will have more separation and hence difficulty in converging steady state solution.
Far is offline   Reply With Quote
Old   June 23, 2013, 05:19
Mikel Mendibe
So, do you mean that is normal to do not convege?
Old   June 23, 2013, 06:16
Far
Sijal
yes, if it is not a design condition. At off design conditions you may need to activate unsteady flow solver.
Old   June 23, 2013, 06:32
Mikel Mendibe
Thank you. I have another question, I want that the wall of the tank heat the fuild that I have. I go to the wall and I put the temperature that I want, is it ok?
Thank you
Old   June 23, 2013, 06:39
Far
Sijal
yes. Also enable energy equation.
Old   June 25, 2013, 03:22
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
You should increase the impeller speed gradually untill to reach your desire speed. For instance, to do a simulation with 400 rpm, first start with 100, then increase it about 20 rpm and go ahead. once I had the same problem too. Try this it helps.
Regard yours
A CFD free user is offline   Reply With Quote
3D mixing tank using MRF/SRF cfd_confuse Main CFD Forum 1 September 13, 2016 02:43
Tank Mixing Problem davidleinster CFD Freelancers 6 June 18, 2013 10:50
Agitator Mixing Tank Mudblood FLUENT 1 November 12, 2010 14:39
3D mixing tank using MRF/SRF cfd_confuse FLUENT 0 October 2, 2010 03:46
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 12:34
