About External Emissivity
Like Tree1Likes
  • 1 Post By ComputerGuy
Old   December 27, 2010, 04:15
Lightbulb About External Emissivity
Cloud Zhang
Cloud is on a distinguished road
Hi everyone
I simulated a case about heat exchanger.I didn't select on radiation model. But about the wall boundary,I selected on mixed and entered 0.3 for External Emissivity,7 for HTC,293 for Free stream temperature,293 for External Radiation Temperature. I simulated another case same as case1 except the wall boundary. I selected on convection and 7 for HTC,293 for Free stream temperatue. I found the temperature of the wall was different.
I want to know the meaning of external emissivity and if I enter a number for external emissivity,the radiation model will be calculated? If the answer is yes, which radiation model will be calculated,RO,P1,S2S or else?
Thanks a lot for your time!
Cloud is offline   Reply With Quote
Old   December 29, 2010, 01:09
Cloud Zhang
so no one knows about external emssivity?
Old   December 29, 2010, 09:42
Real Name :)
ComputerGuy is on a distinguished road
A thermal boundary condition with radiation does not necessarily require a radiation model to be implemented. Recall from heat transfer that the net loss of heat due to radiation is written as:
Q=\varepsilon A\sigma \left ( T_{hot}^{4}-T_{cold}^{4} \right )
where epsilon is the emissivity.
If your surface temperature is quite hot, radiation can dominate the heat loss out of the body, and therefore your choice of emissivity (or whether to account for radiative loss) can make a big difference in your wall temperature.
If you don't enable the radiation boundary condition, Fluent will not account for heat loss this way, and thus the wall temperature will be different. If you choose an emissivity of zero, the solution of wall temperature should be exactly the same as your convection-only boundary condition.
ComputerGuy
Oula likes this.
ComputerGuy is offline   Reply With Quote
Old   January 3, 2011, 22:55
Cloud Zhang
ComputerGuy:
Thanks for your reply. You are right about the wall boundary. And I asked Ansys about the external emissivity and internal emissivity. They said it depends on the adjacent medium.
Old   June 27, 2013, 02:16
gan1990 is on a distinguished road
Hi cloud,
Could you please elaborate on the reply you got from ansys people?
It would be of great help.
Eagerly awaiting your response.
gan1990 is offline   Reply With Quote
external emissivity, radiation model
What's the differences between the external emissivity and the internal emissivity hook FLUENT 14 November 6, 2019 11:21
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
Emissivity for boundary condition ereiss FLUENT 4 August 10, 2012 01:27
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 11:55
Why I can't read one external file? Lee Siemens 7 April 2, 2004 12:25
