Flatten 3D cylindrical surface to 2D XY plot
Like Tree1Likes
  • 1 Post By aerohead
Old   June 27, 2013, 10:51
Default Flatten 3D cylindrical surface to 2D XY plot
aerohead is on a distinguished road
Hi all. I am currently stuck and wondering if there is a way to take a surface pressure contour plot of e.g. a half cylinder and flatten it to an XY plot, with X=X (cm) and Y=theta (degrees or radians). Alternatively, how would this data be exported to TecPlot to achieve the same goal (or can it be achieved by importing the .cas/.dat data into TecPlot)? Thanks for any help!
aerohead is offline   Reply With Quote
Old   June 28, 2013, 04:21
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Fieldview can do this. It has built in fuciton
Far is offline   Reply With Quote
Old   June 28, 2013, 07:18
Thanks Far, I actually figured it out in TecPlot in the end:
define central point of the cylinder > define a new theta parameter > convert theta to degrees if required - included below in case it can help anyone else out in the future:
{y-centre}={Y}-[insert correction value if required]
{theta}=ATAN2({X},{y-centre})
{theta-degrees}={theta}*(180/pi)
Then plot X vs. theta for a contour plot of the desired variable.
fjgwd002 likes this.
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 01:44
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
How to plot the wave contour in ship flow (free surface) problem deddy1973 CFX 6 February 19, 2013 05:49
3D surface plot moloykb FLUENT 0 October 4, 2012 04:54
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
