Pressure based vs density based solver
Old   July 4, 2013, 03:20
Default Pressure based vs density based solver
newbie384 is on a distinguished road
Hi
I use 2d axisymmetric with swirl to simulate heat transfer of fluid between two concentric cylinders, with the inner cylinder rotating and outer cylinder stationary. When I ran the simulation with pressure based solver, it diverged imediately but when I switch to density based solver, the residuals go down slowly (but with oscillation). May I know why pressure based solver gave divergence results? Is it because it is less stable than density based solver?
Additional information of my settings.
1) pressure inlet
2) pressure outlet
3) moving reference frame
4) use stationary wall for rotating inner cylinder
5) use moving wall for stationary outer cylinder with absolute speed=0
Thanks in advance.
newbie384 is offline   Reply With Quote
Old   July 5, 2013, 01:32
Default Is your fluid compress able
sun pengfei
markrenten is on a distinguished road
If your fluid does not have a fixed density , so compress able , the you should choose density based solution .
markrenten is offline   Reply With Quote
Old   July 5, 2013, 02:04
hi
thanks for the advice. my fluid is air and I defined the density to be compressible according to ideal gas law. Density based solver is more appropriate for my case.
Using Density Gradient C_R_G(c,t), Pressure Based Solver Anirudh_Deodhar Fluent UDF and Scheme Programming 1 October 25, 2013 05:43
how to get wall pressure in UDF by using desity based solver helenyuan Fluent UDF and Scheme Programming 0 April 25, 2013 09:41
density based solver and energy ashka FLUENT 0 May 3, 2010 05:46
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
