assign transient random data to inlet face
Old   July 8, 2013, 02:05
Default assign transient random data to inlet face
colopolo is on a distinguished road
Dear All.
Could you tell me how to import/assign time series of velocity at each node (y-z plane) of inlet face?
My transient velocity data is random data so It can't be defined as a profile or function. the velocity is random value in a certain range.
I would like to import/assign time series of random data to each node of inlet face in Fluent or CFX.
For example, the inlet face has 5 by 5 nodes (vertically 5, lateral 5) and the length of time series is 2,000 (time step =0.05, total time : 10sec).
in other words, each node has velocity with 2000 data length.
In this case, what am I going to do?
Many thanks for your comments on this problem.
colopolo is offline   Reply With Quote
Old   July 8, 2013, 04:42
blackmask will become famous soon enough
Use profile if you have the time series of the random data. Otherwise use
DEFINE_PROFILE
UDF macro.
blackmask is offline   Reply With Quote
Old   July 8, 2013, 04:45
DEFINE_PROFILE
UDF macro.
Thanks for your comment. I cannot make profile of my random data.
Old   July 8, 2013, 05:11
If you have data for each node then you sure could use
DEFINE_PROFILE
You need to find the mapping between the random data and the area those data would apply. I assume you could find it some way, e.g., for a uniform spaced mesh you might use something like
#define NX 5
#define NY 5
#define dx 0.1
#define dy 0.2
#define xbl -1.234
#define ybl -5.678
int find_the_index(real x, real y) {
int i, j;
i = round( (x-xbl)/dx );
j = round( (y-ybl)/dy );
return (int)i+(int)j*NX;
If you data is stored in an array named
real data[NX*NY][2000];
you can use
int it = N_TIME;
real x[ND_ND];
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
if ( it < 2000 )
F_PROFILE(f,t,i) = data[find_the_index(x[0],x[1])][it];
else {}
end_f_loop(f,t)
to set the corresponding data for each nodes at given time step.
Old   July 8, 2013, 19:41
DEFINE_PROFILE
#define NX 5
#define NY 5
#define dx 0.1
#define dy 0.2
#define xbl -1.234
#define ybl -5.678
int i, j;
you can use
int it = N_TIME;
real x[ND_ND];
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
if ( it < 2000 )
else {}
end_f_loop(f,t)
Very thanks!!!
Could you mind if I have more questions?
1. do I use 'fscanf' after defined 'real mydata[NX*NY][2000]?
2. data[find_the_index(x[0],x[1])][it]
-> what kind of array type can be read by the above profile?
my data type likes this;
time , z (lateral)_coord , y(vertical)_coord , data1 , data2 , data3 ....................data 2000
0.01 , 0 , 0.2 , x x x x
0.01 , 0 , 0.4 , x x x x
0.01 , 0 , 1.0 , x x x x
0.01 , 0.1 , 0.2 , x x x x
0.01 , 0.1 , 0.4 , x x x x
0.01 , 0.1 , 1.0 ,
after all data of all nodes at one time are mapped, the time goes to the next time 0.02 sec.
in this case how to array my data to easy use your code?
Sorry to bother you and appreciate you spend time with me.
Old   July 8, 2013, 20:46
Something looks like
#include<stdio.h>
#include "udf.h"
#define NX 5
#define NY 5
#define NT 2000
float data[NX][NY][NT];
DEFINE_EXECUTE_AFTER_CASE (read_data, libname) {
    FILE *fp;
    float tmp;
    int ix, iy, it;
    fp = fopen("data", "r");
    for (ix = 0; ix < NX; ix++)
        for (iy = 0; iy < NY; iy++){
            it = 3;
            while(it-- > 0) fscanf(fp, "%f,", &tmp);
            for (it = 0; it < 10; it ++)
                fscanf(fp, "%f,", &data[ix][iy][it]);
int find_ix(real x) {
    return (int) lround(x/0.1);
int find_iy(real y) {
    return (int) lround(y/0.2);
DEFINE_PROFILE(u_profile,t,i) {
    int it = N_TIME;
    real x[ND_ND];
    face_t f;
    begin_f_loop(f,t)
        F_CENTROID(x,f,t);
        if ( it < NT )
            F_PROFILE(f,t,i) = data[find_ix(x[0])][find_iy(x[1])][it];
        else {
            // do something for time step >= NT
    end_f_loop(f,t)
You might need to modify the above code to suit your needs.
Old   July 8, 2013, 20:49
#include<stdio.h>
#include "udf.h"
#define NX 5
#define NY 5
#define NT 2000
    FILE *fp;
    float tmp;
    int ix, iy, it;
            it = 3;
    int it = N_TIME;
    real x[ND_ND];
    face_t f;
    begin_f_loop(f,t)
        F_CENTROID(x,f,t);
        if ( it < NT )
        else {
    end_f_loop(f,t)
Thank for your kindness.
Old   July 8, 2013, 21:26
#include<stdio.h>
#include "udf.h"
#define NX 5
#define NY 5
#define NT 2000
    FILE *fp;
    float tmp;
    int ix, iy, it;
            it = 3;
    int it = N_TIME;
    real x[ND_ND];
    face_t f;
    begin_f_loop(f,t)
        F_CENTROID(x,f,t);
        if ( it < NT )
        else {
    end_f_loop(f,t)
I am sorry to bother you. I mistake my data type.
there is no time column (1st column). actually data 1 is a velocity at time step 0.01, data 2 is a vel. at time step 0.02..
in this case, could you help me please?
Old   July 8, 2013, 21:43
#include<stdio.h>
#include "udf.h"
#define NX 5
#define NY 5
#define NT 2000
float data[NX][NY];
void data_from_it (int it) {
    FILE *fp;
    float tmp;
    int ix, iy;
    char filename[200];
    sprintf(filename, "data %d", it);
    fp = fopen(filename, "r");
            it = 2;
                fscanf(fp, "%f,", &data[ix][iy]);
    int it = N_TIME;
    real x[ND_ND];
    face_t f;
    begin_f_loop(f,t)
        F_CENTROID(x,f,t);
        if ( it < NT )
        else {
            // value for time step >= 2000
    end_f_loop(f,t)
Old   July 8, 2013, 21:51
#include<stdio.h>
#include "udf.h"
#define NX 5
#define NY 5
#define NT 2000
float data[NX][NY];
    FILE *fp;
    float tmp;
    int ix, iy;
    char filename[200];
            it = 2;
    int it = N_TIME;
    real x[ND_ND];
    face_t f;
    begin_f_loop(f,t)
        F_CENTROID(x,f,t);
        if ( it < NT )
        else {
    end_f_loop(f,t)
Thanks again. I owe you a lot.
Old   July 9, 2013, 01:36
#include<stdio.h>
#include "udf.h"
#define NX 5
#define NY 5
#define NT 2000
float data[NX][NY];
    FILE *fp;
    float tmp;
    int ix, iy;
    char filename[200];
            it = 2;
    int it = N_TIME;
    real x[ND_ND];
    face_t f;
    begin_f_loop(f,t)
        F_CENTROID(x,f,t);
        if ( it < NT )
        else {
    end_f_loop(f,t)
#include<stdio.h>
#include "udf.h"
#define NY 5
#define NZ 5
#define NT 20
float data[NY][NZ];
    FILE *fp;
    float tmp;
    int iy, iz;
    char filename[200];
        for (iz = 0; iz < NZ; iz++){
            it = 2;
                fscanf(fp, "%f,", &data[iz][iy]);
int find_iz(real z) {
    return (int) lround(z/0.1);
    int it = N_TIME;
    real x[ND_ND]; /* this will hold the position vector */
    real y,z;
    face_t f;    /* f=all the cell faces on the boundary */
    begin_f_loop(f,t) /* t=given boundary zone, defined automatically when the UDF is hooked to inlet boundary
    begin_f_loop is applied to all the cell faces */
        F_CENTROID(x,f,t);
      /*  if ( it < NT ) */
            F_PROFILE(f,t,i) = data[find_iz(x[2])][find_iy(x[1])][it];
      /*  else {   */
    end_f_loop(f,t)
I changed your code for y-z plane (the dimension of inlet face is 8m (lateral) by 1.5m (vertical).
1) I got an error when this code was complied.
2) the node coordinates of this code and inlet face of real domain are should be matched?
for example, the node distributes by this code are uniform distribution but my mesh of inlet face are non-uniform distribution.
in this case, this mapping has no problem? or I should use exactly same coordinate between your code and grid point of inlet face?
Sorry for you many questions.
I will attached my input file.
Old   July 9, 2013, 02:01
this file is my input file.
the length of sample data is 10 data with y and z coordinate.
Old   July 9, 2013, 05:00
My code above is sketchy because I do not know much details of your grid distribution and/or your input data format. I am a bit frustrated that the description of your input data format changes all the time.
Assume that
1. the y,z coordinates given in "voutu.txt" coincides with the cell centers of the inlet boundary. Otherwise you need to interpolation the data yourself or use profile instead of UDF.
2. your data format is the same as the one given in "voutu.txt". You need to change the NT value (10 here) to the actual number of data points.
#include<stdio.h>
#include "udf.h"
#define NY 5
#define NZ 5
#define NT 10
float data[NY][NZ][NT];
    FILE *fp;
    float tmp;
    int iy, iz;
    char filename[200];
    sprintf(filename, "voutu.txt");
            it = 2;
            for (it = 0; it < NT; it++) {
                fscanf(fp, "%f", &data[iy][iz][it]);
    return (int) lround(z/0.25-1);
    return (int) lround(y/2.0+2);
DEFINE_EXECUTE_AFTER_CASE(init_data, libname) {
    data_from_it(0);
    int it = N_TIME;
    real y,z;
        F_CENTROID(x,f,t);
        if ( it < NT )
            F_PROFILE(f,t,i) = data[find_iy(x[1])][find_iz(x[2])][it];
        else {
    end_f_loop(f,t)
Old   July 9, 2013, 19:06
Assume that
#include<stdio.h>
#include "udf.h"
#define NY 5
#define NZ 5
#define NT 10
    FILE *fp;
    float tmp;
    int iy, iz;
    char filename[200];
            it = 2;
    data_from_it(0);
    int it = N_TIME;
    real y,z;
        F_CENTROID(x,f,t);
        if ( it < NT )
        else {
    end_f_loop(f,t)
Sorry to bother you and very appreciate you help me !!
Old   July 16, 2013, 21:43
#include<stdio.h>
#include "udf.h"
#define NX 5
#define NY 5
#define NT 2000
float data[NX][NY];
    FILE *fp;
    float tmp;
    int ix, iy;
    char filename[200];
            it = 2;
    int it = N_TIME;
    real x[ND_ND];
    face_t f;
    begin_f_loop(f,t)
        F_CENTROID(x,f,t);
        if ( it < NT )
        else {
    end_f_loop(f,t)
First, I compiled your udf but I got an error.
..\..\src\mapped01.c(14) : warning C4996: 'sprintf'이(가) deprecated
C:\Program Files\Microsoft Visual Studio 8\VC\include\stdio.h(345) : 'sprintf'
메시지: 'This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online help for details.'
..\..\src\mapped01.c(16) : warning C4996: 'fopen'이(가) deprecated
C:\Program Files\Microsoft Visual Studio 8\VC\include\stdio.h(234) : 'fopen'
메시지: 'This function or variable may be unsafe. Consider using fopen_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online help for details.'
..\..\src\mapped01.c(20) : warning C4996: 'fscanf'이(가) deprecated
C:\Program Files\Microsoft Visual Studio 8\VC\include\stdio.h(249) : 'fscanf'
메시지: 'This function or variable may be unsafe. Consider using fscanf_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online help for details.'
..\..\src\mapped01.c(22) : warning C4996: 'fscanf'이(가) deprecated로 선언되었습니다.
C:\Program Files\Microsoft Visual Studio 8\VC\include\stdio.h(249) : 'fscanf' 선언을 참조하십시오.
# Generating udf_names.c because of mapped01.obj
So I delete "#include <stdio.h>" then re-compiled it.
I got 2nd error - udf_names.c(6) : error C2449: found '{' at file scope (missing function header?)
udf_names.c(32) : fatal error C1004: unexpected end-of-file found
Could you let me know what is wrong in here?
Old   July 16, 2013, 21:55
I saw a lot of warnings but not an error. Would you please help me highlight the error line?
Old   July 17, 2013, 01:01
#include "udf.h"
#define NY 5
#define NZ 5
#define NT 10
    FILE *fp;
    float tmp, data[NY][NZ][NT];
    int iy, iz;
    char filename[200];
    sprintf(filename, "voutu10.txt");
            it = 2;
    data_from_it(0);
    int it = N_TIME;
    real y,z;
        F_CENTROID(x,f,t);
        if ( it < NT )
        else {
    end_f_loop(f,t)
When I compiled the above file, I got an error like the below;
udf_names.c file in 3d is upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v145\fluent"\fluent14.5.0\sr c\makefile_nt.udf "libudf\win64\3d\makefile" ")
1 file is copied.
(chdir "libudf")()
(chdir "win64\3d")()
# Generating ud_io1.h
mapped01.c
udf_names.c
udf_names.c(20) : fatal error C1004: unexpected end-of-file found
Old   July 18, 2013, 20:21
This is not the code I wrote for you, it it?
Old   July 24, 2013, 03:49
I am sorry for late reply. I was out of office.
Yes. The above error was happend when I compiled your code without "#include<stdio.h>".
When I compiled your original code,
Copied d:\gambit\2013 cyber wind tunnel test\wt00/D:\Gambit\2013 Cyber Wind Tunnel Test\WT00\mapped00.c to libudf\src
Creating user_nt.udf file for 3d ...
1 file was copied.
(chdir "libudf")()
mapped00.c
..\..\src\mapped00.c(17) : warning C4996: 'sprintf' deprecated
message: 'This function or variable may be unsafe. Consider using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online help for details.'
..\..\src\mapped00.c(20) : warning C4996: 'fopen' deprecated.
C:\Program Files\Microsoft Visual Studio 8\VC\include\stdio.h(234) : 'fopen' .
message: 'This function or variable may be unsafe. Consider using fopen_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online help for details.'
..\..\src\mapped00.c(24) : warning C4996: 'fscanf' deprecated C:\Program Files\Microsoft Visual Studio 8\VC\include\stdio.h(249) : 'fscanf'
message: 'This function or variable may be unsafe. Consider using fscanf_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online help for details.'
..\..\src\mapped00.c(25) : warning C4996: 'fscanf' deprecated.
blackmask00.obj : error LNK2019: lround unresolved external symbol ( find_iz function).
blackmask00.obj : error LNK2001: lround unresolved external symbol .
libudf.dll : fatal error LNK1120: 1 unresolved external symbol .
type
Done.
Blue is just warning and bold character is error mesage
Old   July 24, 2013, 04:26
Add
#include <math.h>
after
#include <stdio.h>
Create an internal face aylalisa OpenFOAM Pre-Processing 1 June 19, 2013 12:02
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Inlet profile from 2D velocity and turbulence data Attesz OpenFOAM Pre-Processing 2 March 11, 2012 06:09
Map external data (heat flux in) on solid face jerry1977 CFX 2 January 31, 2012 13:32
Transient Inlet boundary condition - fully develop Omer CFX 3 November 28, 2006 16:22
