y+ in a turbulent flow
Old   July 8, 2013, 11:31
Default y+ in a turbulent flow
zacfranki is on a distinguished road
Hi everyone,
i'm trying to model the turbulence in a free convective flow. What is an adequate value of y+ (so i can see if the dimension of the grid that i've generated is correct?). Now i'm using k epsilon model with standard wall functions.
David
Thanks
zacfranki is offline   Reply With Quote
Old   July 10, 2013, 12:31
delaneyluke is on a distinguished road
Hi David,
First you decide which turbulence model is best suited for what you're trying to simulate.
Then you decide on the wall treatment you want to use.
You Y+ value will depend on both these things.
For example, the k epsilon model with standard wall functions requires a high value of Y+. generally between 100-300
Thanks & Regards
Luke
delaneyluke is offline   Reply With Quote
turbolence convective
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 17:51
Difference between recirculation zone and turbulent flow region ashtonJ Main CFD Forum 0 September 16, 2011 03:46
Patch a bubble inside turbulent flow Helmi FLUENT 0 February 4, 2011 04:54
Turbulent flow through hexagonal circular pipe yogesh@cfd Main CFD Forum 0 November 9, 2010 23:10
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
