July 12, 2013, 16:23 |
reversed flow
sajjad bouzari
Rep Power: 13 |
hi every one
I'm modeling blood flow in Aorta and I have velocity inlet boundary condition and pressure out lets when I try to iterate, I see this in fluent " reversed flow in xx faces on pressure outlet x". I can't change my boundary conditions so can you help me fix the problem. and also my case is Laminar , steady ,3d and i use "Least Squares Cell Based" I really need your help
best regards |
July 14, 2013, 23:12 |
Chris DeGroot
Rep Power: 17 |
Looks like your problem is not converging very well. Try adjusting relaxation settings and maybe try coupled solver. Also make sure the outlet is far enough downstream that back flow wouldn't be expected physically.
July 15, 2013, 02:27 |
Check
Jasdeep
Rep Power: 13 |
Check your flow direction as well. Or let it iterate for some time, it might stabilize.
July 15, 2013, 03:04 |
Firas
Rep Power: 12 |
I agree with our friend check comment ....let your iteration go ahead and see the result in quess reversed flow will finish after numbers of iterations
Significant Reversed Flow at Outflow Problems [ANSYS FLUENT] | NormalVector | ANSYS | 1 | May 15, 2012 23:50 |
Reversed Flow for a tenth slice of a rotor | neptunemmx | FLUENT | 10 | January 30, 2012 13:51 |
Reversed flow...>>>Please HELP...! | sushii | FLUENT | 14 | October 29, 2007 04:27 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
reversed flow | Sastry | FLUENT | 5 | March 22, 2007 08:05 |
